Question about Panasonic PT-51G36 51" Rear Projection Television
Tv getting darker
I have a 6 yr old rear projection panosonic tv. the screen has been getting darker and darker. color seems to be fine. just dark. I have adjusted the brightness level up all the way but still on dark side. any ideas?
  • 375 Answers
SOURCE: Panosonic 50" LCD 1080i HDTV screen picture faded
try setting your menu;s to adjust the picture settings
Posted on Aug 23, 2008
  • 192 Answers
SOURCE: LG Projection TV has dark picture
Normally the main cause of any DLP having a dark picture is the lamp. I would replace it and it should look like a new set again.
Posted on Jul 01, 2007
ctf1800
  • 4402 Answers
SOURCE: hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
  • 198 Answers
SOURCE: Colors - particularly green - bleeding on Panasonic 52" rear projection tv
1)Wipe the screen clearly without leavin anything on the screen.This may be one of the reason.
2)Did you by any chance apply pressure on the screen. if yes then it may be the reason for this. This may be the other reason.
What was the exact reason for this to happen.
Posted on May 30, 2008
800pctechs
  • 39 Answers
Replace the colorwheel.
Posted on Oct 28, 2008
Color looks white washed!!!
there are in the older rear projection sets lens for those that do not use a lamp for a light source.
In the older sets there are three large black lens that can be seen and reached with the rear cover off---if there clean them as they are the light source in those sets and if dusty picture will look dull and darker than it once did.
If in doubt shoot me a model number.
Dec 05, 2012 | Toshiba Televison & Video
My HLP5063W tv comes on and works for 3 to 5 min then the pictures gets dark and the colors are distorted. The remote no longer operates the set and I can not turn it off using the front or side switch. ...
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours which is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen. Try Encompass .com ; shopjimmy.com
Jun 11, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
A Dark Bar at the top of the screen that looks pink against white
the light engine is defective if you have black bars that look pink.
Sep 05, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen getting dark
If you have never changed the lamp this is more than likely the issue, as the tv ages the lamp looses brightness. Most lamps are rated for 3000-5000 hrs of use. Replace the lamp assembly part # UX21514 and you will notice a much brighter picture. You do not mention if the tv plays the right colors on the entire screen. These have had light engine issues.
Good luck with it
JOTVGUY
Apr 07, 2009 | Hitachi 50VX915 Rear Projection Television
Mitsubishi WD-73827 with degrading color
Good Day;
More then likely your 2005 MODEL has a bad "LIGHT ENGINE". Call an Authorized Service Center and have them give you an estimate, then call MIT's and try to get them to give you a "CONCESSION". It's costly. Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture gets darker
Apparently there is a loose connection somewhere. Please have unit checked out by a pro tech
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
Hitachi 52 projection tv
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Panasonic PT-51G36 51" Rear Projection Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
