Question about General Electric WHDSR316G Top Load Washer
My washer wont spin at all, it will fill and drain fine anyone have suggestions?
My GE washer is not spinning I want to check the solenoid where is it?
    Sergeant:
    Champion:
  • 205 Answers
Hello mam if your machine is not spinning then its not the problem of solenoid problem will; be in the timer.and for your knowledge solenoid functions as a control valve for the water flow.
Posted on Sep 22, 2009
Lg top load washer keeps filling and has to be manually stopped but it will drain when put on the spin cycle.
HI,
From your description, it sounds like there may be a problem with the inlet water solenoid valve(s). They can stick after several years of use. The se valves are located in the machine, just inside where you connect the water hoses.
Jul 25, 2015 | LG Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
It fills up..washes..but wont drain or spin out..
I had the same problem. Checked the pump and it ran fine. Took off the door locking mechanism and put 120 ohms into the wax motor part and it tested fine too. I read about problems with that wax motor so I replaced the complete door switch today for $71.00 and the washer runs perfectly now. If it won't spin or even fully drain I suggest replacing the door switch.
Jul 14, 2009 | Washing Machines
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Model #:WBSR3140DWW
My GE washer will not agitate or spin. Will fill up with water but wont spin. Looked at motor and it has a green light that flashes about every second constantly. I can turn the pulley both ways. Does anyone have any suggestions
Oct 18, 2008 | GE WBSR3140D Top Load Washer
General Electric WHDSR316G Top Load Washer Logo
186 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
