Question about Philips 60P8341 60" Rear Projection Television
On/off switch flashes when trying 2turn on, makes high pitchd chirping noise (not firing up)
60p8341A - light flashes once turnd on and makes a high pitched chirping noise (not firing up):( sounds like it wants to turn on howevr doesn't
  • Philips Master
  • 5,568 Answers
Poorly made transformers can cause odd noises if the circuit in which they are used continually tries to start but is shut down again immediately. I would suspect some component in the main power supply, quite possibly a failing electrolytic capacitor causing it to cycle.
You might check with Philips to see if they have a repair or replacement program for the supply. You will have to gain access to the guts; probably via a lower rear panel and I would allow the set to stay unplugged overnight as some parts remain alive and others can carry a charge for hours. Look for a board with larger-than-average components on it, particularly the mentioned transformers which are block-like objects and also the board will have larger cylindrical components on it as well. If will have one or more part numbers that a service center can use for reference.
Posted on Apr 19, 2009
Maytag electric dryer, lights flash, chirping
I had this happen with a maytag washing machine. The repair guy replaced a board and it worked fine. I'm afraid that's what happened here.
Nov 13, 2012 | Maytag Dryers
Hitachi 53UDX10B power button flashes, chirping noise, LEDs flash
The convergence issue might not affect the TV to the point of not turning ON.
The chirping noise you hear, it means there is a short circuit in the circuitry, possible the HOT or power supply assembly.
Apr 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
CHIRPING SAMSUNG PROJECTION TV
Chirping is set is in shutdown---most likely in High voltage area of set.
Jun 11, 2012 | Samsung Televison & Video
On the remote I will push the unlock button, then the car's horn honks and unlocks the doors. It also honks when I want to lock it. I am only pushing the lock or unlock button once. I'm not in the...
You can disable the chirp confirmation by using the following procedure
1. Turn the ignition on
2. Turn the ignition off
3. Press the valet switch 5 times, wait for the Status Light to flash twice, the parking lights to flash twice and the horn to chirp twice.
4. Press the valet switch 4 times, the MARS unit will respond with 4 Status Light flashes and horn chirps
5. Press the transmitter START button, the MARS unit will respond with 3 Status Light flashes and horn chirps
6. Turn thr ignition on to exit program mode
May 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
My 97 jeep grand cherokee makes a chirping sound under front
The noise and the light may or may not be related. The noise may be the wear indicator on the brake pads touching the rotor (they are supposed to do that when brakes are worn) The abs light triggers off a wheel on the axle end. If you have a bad joint on the axle, it could be noisy and causing the wheel to not have the proper clearance to the abs sensor. You really need to take the wheel and brake assembly off and carefully inspect everything. Make sure all abs sensor wires are undamaged...it doesn't have to be at the same wheel that's chirping.
Sep 26, 2009 | 1997 Jeep Grand Cherokee
G36710 RCA console TV just quit while watching... makes noise
a shorted horizontal output transistor will make a funny squeek or chirp noise when turning on the tv. Usually mounts on a metal dissipator near the bulky plastic part with the red thick wire coming out of it.good luck!
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
RCA 31" TV pakes high pitched chirping noise
Did you check the Horizontal Output transistor to see if it were shorted, and also check the MOSFET of the switching power supply.
Jul 25, 2008 | Televison & Video
Samsung PCL542R Chirping noise
There is problem in sound IC. First check it
Feb 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
PT-43LC14 No Picture, chirping sound when turned on
Most of the time, when there is a chirping comming from a TV set, there is a short somewhere inside the TV set. That chirping noise is the TV's power supply starting up and shutting down because of a heavy load on the power supply. These sets have no user replaceable parts inside them, so play it safe, and call out a pro to assist you in this repair. good Luck PS Please do not forget to rate this thread.
Dec 11, 2006 | Panasonic PT-43LC14 43" Rear Projection...
Flashin power light - wont come on
The "green light flashing to the chirping" circuit may be defective.
Not a basic diagnosis--service literature and/or knowledge of each green light circuit will be needed.Possible shop repair.
Oct 05, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
