Question about Sewing Machines
My needle keeps breaking. Which way does the flat part of the needle shaft go in. Does it face the wheel, towards the back or to the left. I cleaned and oiled the machine so the only thing I can think of is that I'm putting the needle in wrong. My machine is a Necchi model # 524FB. I've had it for nearly 40 years but I haven't used it in quite some time and I can't find my manual.
  • 3 Answers
The flat of the needle normally goes to the back. If the problem persist, the timing of the machine is not correct. Refer it to the nearest service centre,
Posted on Apr 19, 2009
How to replace needle in bernina active 240 machine, needle keeps breaking help please
Check to make sure you are installing the needle facing the correct direction--usually the flat side faces toward the back of the machine. Also, is it the correct needle--130/705? Is the needle pushed as far up as possible before it is tightened? Check the machine by handturning the handwheel rather than trying to run the machine.
If those check out, then it's quite possible the machine is knocked out of time. Take it for service. Refrain from trying to sew as long as the needles continue to break. It could cause more damage--costing more to repair..
Oct 09, 2017 | Bernina Sewing Machines
What position is needle supposed to be in when you replace it. Is needle eye suppose to be facing you or is it to be threaded from the side?
Depends on your sewing machine. Most needle flat surfaces face the back of the machine so the eye is threaded from the front, but on some machines the flat surface faces toward the harp of the machine (so the thread is threaded through the eye from the left side).
FWIW, usually, if the bobbin loads from the front of the machine the needle's flat surface faces the back. If the bobbin loads from the left side, the needle's flat surfaces faces the harp.
If you install the bobbin, thread it, and it will not pick up the bobbin thread or create a stitch, then it is likely the needle is installed incorrectly. Also, installing the needle the wrong way could cause it to strike and break, so test it SLOWLY!
The ideal would be to consult the owner's manual. Search for:
Make Model manual
or
Make Model threading
Mar 19, 2017 | Sewing Machines
I took my needles out to change them and can't get them back in!
Heather, switch off machine from electric supply.gently lay machine on its back, you will then be able to look at the needle holder .remember the needle has a flat side and this must corispond to the shape where the needle enters into the space for it . be sure you tighten needle into place with the tool provided for the job. Reston machine back onto it's base . Tread up machine and slowly turn by hand the side wheel to make sure the needle is in the right place. When this is working you can refit electric cable as continue sewing. P'S try sewing on a bit of spare fabric to make sure all is well..happy sewing , lois
Aug 20, 2016 | Sewing Machines
Crazy question but .....how do you center the needle? Always sits to the left
Don't know about your particular model, but maybe left is the normal "resting" position. When on zigzag it will move to the right then back to the left. As long as all of your different stitch patterns keep the needle between the limits of the hole above the shuttle and does not hit the machine bed then I would best guess everything is fine.
Hope that is of some help.
Jan 21, 2016 | Singer 3321 Talent Sewing Machine
Troubleshooting my Necchi sewing machine
Make sure that the needle is in the centre position and not in the zig zag or pattern position.
Jan 10, 2015 | Necchi Sewing Machines
Janome s950 sewing machine top thread keeps breaking?
Well, Madalyn, when was the last time you oiled the machine. Go to http://fixsewingmachine.com for tips on that and on tension, timing, cleaning the shuttle race, etc. , but now, let's talk about this particular problem you are having: it sounds to me like you could use a new needle of the correct size for the type of fabric/weight of fabric you are sewing. Also, sometimes sewists think they have that needle all the way up in the needle bar shaft, but...oops! no, it's not, and sometimes they also forget that the flat side goes toward the back of the needle bar. Also, sometimes sewists (not necessarily YOU, Madalyn, but SOME sewists, forget to turn the handwheel toward themselves and keep that presser foot in the UP position when they thread the machine. What happens? Yep! The tension discs do not open all the way up for thread to locate the tension discs and creates a problem. Make sure you clean the shuttle, the feed dogs. No big deal. Relax, get the little brush. Much success!
Jimmy
Apr 12, 2012 | Sewing Machines
Elna 6200 jammed on bobbin refill setting
Remove thread. Remove the needle plate. Turn hand wheel toward you. Rethread machine. Make sure presser foot in up position when you thread needle. Make sure needle all way up in shaft, flat side back and more rounded side facing you Turn hand wheel toward you again and observe the following: As needle comes down, make sure the needle's eye makes pass by the scarf of the needle. Hope this helps, and if not, try sewvacdoctor.com
Apr 03, 2012 | Sewing Machines
I have a BROTHER DISNEY pe770 EMBROIDERY MACHINE, THE THREAD IS BREAKING
Upper thread breaks--needle may be in backwards--
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
Mar 24, 2012 | Brother PE770 Computerized Sewing Machine
When it changes from straight stitch to sepintine and back to straight it skips lots of stitches. Just paid $300 for a new shaft.
try these suggestions & see if they help
Sewing machine skips stitches
1.needle inserted incorrectly--flat side of the needle faces the shaft
round needle--groove of needle faces away from the shaft
2.Correct needle insertion is mandatory for proper use.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the needle. Place the new needle in the clamp with the flat side of the needle facing the back of the machine.
If round needle--the groove in the needle faces away from the shaft
Push needle all the way up to the stop or as far as it will go.
3.possible bent needle--lay needle on flat surface & roll needle over, if the needle does not roll good -replace
4.blunt needle point--needle makes a popping sound when needle penetrates the fabric--replace needle
5.needle not all the way up in needle holder--loosen needle clamp screw & push the needle up until it stops then tighten screw
6.incorrect threading--one step missed in sequence of threading can cause machine to skip stitches
7.wrong needle in machine--check instruction manual--some machines can use a generic needle with no problem--some can't--
8.size of needle & thread not compatible--
Using the wrong type needle can cause problems,,
A needle to fine for heavy fabric can bend or break when it hit's the fabric
And a too large needle can make puncture holes in the fabric and pull unevenly while stitching
Sep 15, 2011 | Baby Lock Sewing Machines
My Husqvarna Zig Zag Model 10 30 has seized I can't even turn the wheel for the needle manually, do I just oil as many parts as I can and keep trying?
Yes, but try turning the hand wheel towards the back of the machine (if you are facing the hand wheel, turn it clockwise) and pick up some self penetrating oil such as Tri-Flow. I would bet that the bind is either behind the hook or on the top shaft towards the right side.
-Chris
Jun 14, 2010 | Husqvarna Designer I
Sewing Machines Logo
338 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
