Question about Acer Aspire 5315 Notebook
My laptop will not power up
I have an acer laptop & it will not power up I have checked my power supply cord & my battery ,what could be wrong with it ?
  • Steve Allison
    Steve Allison May 11, 2010
    How did you 'check' it?
  • 3 Answers
Try this. Turn it off. take out the battery and press the on button for 2 minutes before you release it. sometimes this will reset a computer and then it will start up. Then you can put the battery back in
Posted on Apr 19, 2009
Battery of my Acer Aspire 4810T does not work. With the power supply plugged in, the indication of the battery is "85% available (plugged in, not charging). If the power cable is disconnected, the...
There are three possible reasons why your computer is experiencing this power problem. What you need to do is to isolate the component that's causing it.
These are the parts which should be checked:
1. Power supply
2. Battery
3. Motherboard of the laptop.
Here's the procedure that you have to follow:
1.
Remove the battery from the computer.
2. Power the computer up with the power cord only without the battery on it.
3. Check if it works perfectly without any problems even if the battery is out. If it works, then, the battery needs to be replaced. (Note: Batteries are disposable parts. They usually die after 2 years of usage depending on how you use it.)
4.If no go even without the battery on it, check the ac adapter or cord if there's a light lit on the box of the cord. If no lights on it, double check the connection. If connections seem ok but no power, then, replace the power cord.
5. If power cord seem fine, check the hole in the computer where you plug in the cord. What you need to check is if there are any sign of damages. Wiggle the cord and see if there are lights lit in the laptop.
I hope this help.
CARLO
Apr 13, 2011 | IBM ThinkPad T40 2373 Notebook
Acer extensa 5620 will power on. The battery light on with the battery and power cord. But it will light on with the just the power cord or jujst the battery.
As long as it is working OK, then the battery light, is only an indicator, A laptop should work, either way, with just the battery, or just the Power Supply, and of course both. Try adjusting you Power Settings and see if that alters anything. Also consult you manual about the issue.
Apr 08, 2010 | Acer Extensa 5620 Notebook PC
Acer Asipre 5315 laptop Battery A/C supply plugged in, hit power switch and the power light blinks 2 (maybe 1 time)times but the unit does not power on.
remove the battery and power cord then remove the battery on the mother board, hold down the power button for 60 seconds to drain the capacitors, if that doesn't work it's the motherboard that should be replaced.
Feb 19, 2010 | Acer Aspire 5315 Notebook
My ACER 5570z will not start up. When power cord
You most likely have a broken DC Jack on the motherboard. Thus, the battery cannot get a charge and the power supply is not making a connection to the system board because of the broken DC Jack.
Good Luck
Sep 29, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer 5050 laptop no power
I have the same thought.
But please check the new power adaptor has the same output voltage as the old one.
If same the power supply unit needs to be changed on the laptop.
All the best!
Sep 02, 2009 | Acer Aspire 5050-3242 Notebook
I have an acer aspire 3690, and when I plug the power cord in to the laptop, the battery does not charge any more. What is wrong with it?
It one of two things wrong here,
1) have your replace the battery yet?
2) Does your AC cord work properly?
Check that and let me know.
-Charlie S.
Jul 18, 2009 | Acer Aspire 3690-2196 Notebook
Battery not charging
It could be the power cord if without the battery the laptop will not power up with the cord.
However, if it does power on, the power cord is fine and it could be a motherboard problem
Mar 05, 2009 | Acer Extensa 4620 Notebook
Problem with battery or power cord?
it could be a short in the power cord or a lose dc jack in the back. what model acer is this for as power packs for them dont cost to bad.
Nov 29, 2008 | Acer (56.04145.901) (5604145901) Power...
Acer Aspire 3680 Laptop Can't Power Up
acer aspire 3680 no power on, found 2 short circuited surface mount capacitors on motherboard replaced lapton power on works fine. Edward
Jan 19, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5315 Notebook Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
