Question about Toshiba 65HM167 65" Projection Television
Toshiba 65'' Lamp not working
I HAVE A 65HM167 - yellow blinking/red solid led. Voice recorded message states: lamp not working and E8222 AND L8222. According to the manual I need to replace lamp. Will one lamp cover both message codes?
  • 537 Answers
SOURCE: Solid yelow led and the red led is flashing
Check your manual or:
http://www.toshiba.ca/web/pdf/5056HM66_EN.p.pdf
Use the quick restart procedure
Posted on Jul 14, 2008
SOURCE: Yellow blinking light on Toshiba 65HM167
Guest...you are not going to have any luck! If you can believe this our TV is STILL broken. And it has been since July 7th!!!! I have been fighting with Toshiba I have reported them to bbb and also to the federal trade commission. I have faxed the work order from the first time someone came out to look at it, a copy of my cell phone bill to prove the first time I called was really way back in July!! It is a main board in the tv and they keep telling me it is on "extensive backorder" Finally they offered us 3 options...a refurbished 65in, a brand new 52in LCD or a full refund in 6 weeks!! I will NEVER buy a Toshiba anything again. I suggest you call this number 1 800 351 5481. When someone picks up tell them you need to talk to Toshiba in regards to a TV, they will transfer you directly to them. The sooner you start a file with them the better because as you can see when I posted this and yes it is still broken. I have also faxed copies of everything we have been dealing with to the offices of Phillip Schoonover who is the CEO of circuit city where we bought the TV and also Atsutoshi Nishida the CEO of Toshiba. You should just ask to talk to Evette....she is the customer service supervisor who I have been dealing with. If there is anything else I can help you with please let me know....trust me I have ALL the information you will need.
Posted on Sep 21, 2008
SOURCE: Cant find a ballast
The ballast is actually a switch mode power supply that powers the lamp. It is an
integral part of the light engine and is not replaceable. The light engine has a price
tag of $950. If you replaced the lamp with an after market one and not the Toshiba
lamp you can experience the same problem. Some of the after market lamps will
not fire at the same voltage as the Toshiba. The blue led will come on solid and the
yellow blinking. It will try to start 8 times then give up.
Charlie
Posted on Dec 31, 2008
  • 18 Answers
SOURCE: My toshiba 50HN67 TV won't power on.
I have the same TV and had the same problems. What worked for me. I tuned off the set unbluged the TV, waited about five minutes and replugged and resolved my problem. Hope this works for you.
Posted on Aug 22, 2009
  • 556 Answers
SOURCE: Solid yellow lamp light AND flashing yellow status light
start with the lamp.
Posted on Sep 21, 2009
Ballast problem?
The ballast is possible if it does not light the lamp even for a few moments----about the lamp= generic bulb or a OEM Toshiba lamp unit?
Aug 27, 2012 | Toshiba 65HM167 65" Projection Television
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I have a Toshiba model 65HM167. The bulb exploded about 6 months ago so I replaced it and everything worked fine until now. Now the TV will power on and I will get sound but no picture. The yellow light...
Unfortunately lamps go bad without the visible state of being bad. I don't know who or where you bought the lamp from but I order all my lamps through dlplamps.com
The clicking sound you hear is the lamp inverter igniteing the lamp but the lamp is bad.
Nov 29, 2010 | Toshiba 65HM167 65" Projection Television
What is a pc broad cause my tv won't come on and i have heard it need a pc broad
If you are seeing the yellow light blinking 3 times repeated over and over the boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip2_bing.gif the files and folders,copy the unzipped files & folders to a SD card (like a camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in2_bing.gif the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
May 02, 2010 | Toshiba 65HM167 65" Projection Television
My Toshiba Model no. 65HM167 does not power up. The lamp light on front of t.v. flashes and thats about it. I replaced the lamp but still no go. Help.
CK the Lamp Fan if it stops running Lamp will not light and if thats ok Ballast Board it is what turns Lamp on!
Visit Encompass Parts Distrubtion for Parts List and numbers 1-800-638-3328
Mar 23, 2010 | Toshiba 65HM167 65" Projection Television
Tv will not turn on. lamp light is flashing 3 times. i put a new lamp in it and have the same problem
The boot data is corrupted. Download the firmware update from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
Feb 24, 2010 | Toshiba 65HM167 65" Projection Television
Toshiba 65hm167 black screen with video input
That is correct, if the lamp was bad then you will not see a picture at all. The fact that you are getting menu means the lamp is good and most likely the processor and light engine are also okay. Check other inputs to see if you have the same problem on all the inputs.
Nov 02, 2009 | Toshiba 65HM167 65" Projection Television
Cant find a ballast
Charlie
Sep 29, 2008 | Toshiba 65HM167 65" Projection Television
Toshiba 65HM167 65" Projection Television Logo
997 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
