FixYa.com
Tags:
Fax Machines
Generic problem for all Fax Machines
Error message Sharp FO-4450 Fax machine (by 3 users)
posted by rdeher on Sep 19, 2007
I keep getting the message "drum life reached" and alarm button on,even though I've changed the drum and toner cartridge -
it is working fine - just the error message which is annoying. Does anyone know how to reset it? Can't find info about it in the manual. rdeher
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Veron, posted on Feb 13, 2008
I have replaced both the drum and toner but still get a message: "Toner Life End, Open the Front End and Replace the Toner"
Comment by Guest, posted on Nov 27, 2007
check drum cart. and alarm. We replaced drum cartridge and toner cartridge and reset counter. alarm light still on and message still there "check drum cart."
Best Solution
posted on Jan 16, 2008
FixYa! (100)
jtechie
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
Press life "2" start for toner.
And life "3" start for drum.
These will reset the counters.
If you are having a "check drum error" then you have broken the sensor arm that is attached to your lid.
Call a technician in your area.
Jeff
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP 1010 Plain Paper Thermal Fax HP 1020xi Fax HP 1230 Plain Paper Inkjet Fax Panasonic Panafax UF-790 Plain Paper Laser Fax Panasonic KX-FL501 Plain Paper Laser Fax Panasonic Panafax UF-885 Plain Paper Laser Fax Panasonic Panafax UF-880 Plain Paper Laser Fax
Can you Help with these Fax Machines problems?
Brother FAX-8360P Plain Paper Laser
Blank Pages
I can send ok on the fax jsut... Answer This...
Fax Machines
Hi, Our Ibico IL19VT Laminator...
Hi, Our Ibico IL19VT Laminator... Answer This...
Fax Machines
can not receive fax costum
can not receive fax costum ring... Answer This...
Brother IntelliFax-2820 Plain Paper Laser Fax
brother FAX-2820
my brother FAX-2820,I can send... Answer This...
Repair Service
Find Fax Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
