Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell Clean Shot brushes do not turn, belts in place.
I have used the carpet cleaner machine 6 times or less in under a year, and the brushes will not turn. The belts are in place, I do not see rotation on the "axle" that would turn the belts.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rgh
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell carpet cleaner belt fell off, how do I replace it
Which belt? There are 2 on a Pro Heat. The pump belt which is pretty straight forward to put on. If it's the brush belt you will probably have to take the brush off. Re-rail the belt and then put the brush back in the holder arms while keeping the belt in the groves. BUT if the belt came off in the first place it's probably shot. Before you go to the trouble, get a new belt.
Sep 25, 2014 | Bissell 1699 ProHeat Clear View Upright...
When we first turn on the cleaner, the brushes will turn, but then they stop. What do you think is wrong? Thanks
The belt is shot and when it heats up it strecthes even more so that the brush will not turn then... change the belt and your good to go...
heatman101
Apr 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Brush not moving in Bissell pro-heat
if the belt is more then 6 months old or more, then the belt will have to be replaced reguardless of the way it lookes. belts can stretch over time and when you put the machine on the carpet the friction causes the brush to stop because the belt has stretched. i would try this first. hope this helps
Jul 30, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My brushes stopped
the brush is probably jammed, so the belt wont turn it. make sure the unit is unplugged and check for and remove any foreign object contamination
Jul 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
We have a Bissell Proheat Cleanshot 2X Model 9500 Steam carpet cleaner. The first time we used it things were great. The second time we used it it left tracks in the carpet. We have no idea what caused...
First things first. It's only the second time you have used the machine, so it must be fairly new. If you have a receipt and the unit is less than a year old you should take it to an authorized Bissell repair center and have the machine inspected under warranty.
Otherwise, The jets on this unit clog easily, there are two of them and you can locate them under the recovery tank towards the front of the machine, and blow them out with an air compressor. To prevent the jets from clogging in the future make sure to flush all shampoo out of the machine with clean water when done using it. That is most likely your problem.
If it is leaving black streaks on your carpet it could be coming from a burnt belt or melted brushroller part, in which case inspect the belts and brushrollers and replace the damaged pieces.
I hope this helped
Good Luck
Nov 21, 2008 | Vacuums
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Replacing the brush drive belt on model #1697 carpet cleaner
To replace the Brush Belt:
You will need a Phillips head screwdriver.
1. Turn the machine OFF and unplug from the wall outlet.
2. Step on the release pedal to lay the handle down on the floor.
3. Remove the Tank-in-Tank and SmartMix Bottle and set them aside.
4. Turn the machine over to expose the brush.
5. Look for the red retainers, which hold the black brush arms and gear-type brush belt in place. Unscrew the two Phillips head screws. Set these parts aside.
6. Loop the replacement brush roll belt around the brush end and the red pulley with the ridges.
7. Alternate holding each brush arm in place while replacing the red retainers.
8. Replace the Phillips head screws and turn until snug.
9. Turn the machine right side up to replace the Tank-in-Tank and SmartMix Bottle.
If you require additional assistance, please call BISSELL Consumer Services Toll free at 1-800-237-7691 Monday through Friday from 8 a.m. to 10 p.m. or Saturdays from 9 a.m. to 8 p.m. ET.
Jul 07, 2008 | Bissell Vacuums
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
299 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
