Question about Sharp Office Equipment & Supplies
I own a sharp SF-7900. My pages are coming out black
I own a sharp SF-7900. My pages were coming out black, replaced the toner and they are still black pages. What could be my problem? Can anyone tell me where I could get a manual for this machine?
  • Sharp Expert
  • 1,326 Answers
I'm sure you may find a manual, but your copier is rather old.... When you make a copy do you get a error code? How about when you make a copy, do you see the scanning lamp turn ON? Here is you thing you can try, make sure the Primary Corona unit is pushed in all the way in. It has a grey handel on it and it should be found right above the Drum... Good Luck
Posted on Apr 20, 2009
Sharp AL-2020 - Copier Producing Copies with Faint portions at Top Middle and Bottom of Page
This if often a faulty toner issue. If you are refilling it might be time for a replacement carrier. Alternatively have you checked your transfer belt for areas of damage
Jun 30, 2014 | Sharp SF 2020 Copier
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
How to check the meter
just push the 0 key or cancel key, just try you can read the counter
Jun 24, 2013 | Sharp SF-2025/2030 Copier Toner Black...
I have a Sharp SF-2020 pedestal copier. The red triangle dots appeared above the yellow digital copy #. Prior to this, it took over a minute for the copier to "boot up". I added factory toner...
Hi r_finch424,
The blink red triangle means that the toner is completely over and can't be refilled. The toner cartridge comes with on-chip sensor that counts the toner life. To resolve this issue, you need to replace a new toner cartridge.
Hope it helps.
Thank you for using FixYa.
Aug 29, 2011 | Sharp SF 2020 Copier
When ever we try to print or copy it always jams at the exit feeder, and always has huge black smears all over the far end of the page.
Hi this issue is going to be an issue with the exit sensor and fuser unit will cause black smears check the fuser unit rollers if worn replace the fuser unit assembly
Feb 16, 2011 | Sharp SF 2040 Copier
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Sharp SF-7320 produces grainy copies
Clean the drum unit seal blade thats leaking or replace it.
Nov 11, 2009 | Office Equipment & Supplies
My copier is a Sharp SF Model 2215. I replaced
It is the drum.
Reasonable cost? That's up to you.
Call a few service depots and ask. Then decide if you want to invest the cash.
Jul 14, 2009 | Sharp AR-M205 Copier
Sf 7800 sharp copier
-Did you try to replace the Toner Cartridge? if not try to replace and installed properly.
or check the Toner Cartridge if installed properly.
Sep 20, 2008 | Sharp AL 1215 Black and White Copier
97 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
