Question about Car Audio & Video
Car stereo i blew my kicker cvr sub. the coil burnt. i know i can get magnet wire and rebuild the coil. how do i get to the coil? seems to be all glued together, but i dont want to pry or cut before i know for sure.
  • 752 Answers
Sorry to burst your bubble, but you CAN'T rebuild the coil, for a multitude of reasons. It's THEORRETICALLY possible, but pragmatically IMpossible. Trust me, I know. Yes, your speaker is glued together (with VERY strong glues. When you dismantle a speaker you have to replace many parts including the surround and spider...). With that said.... There ARE shops that can repair speakers (and, no, they generally don't handwind coils...), but they are far and few and pretty expensive. A base model sub like that would't be economical to repair. I don't know where you're at, but the only one I know of is "The Circuit Shop" in Grand Rapids, MI. feel free to google them and call for a quote.
Posted on Sep 20, 2007
    New Friend:
I live outside the us, and we sometimes rebuild our subs when they are blown. what you need is a solvent like accetone to soak the glue holding the outer suspention to the frame and the outer side of the spider. after the solvent does its stuff, the glue will soften an you can gently pull at the edge of the suspention and spider lifting it away from the frame. you will need a hot soldering iron to desolder the pigtail wires that connect to the terminal. and then just lift out the whole cone/coil assembly! but as far as rewinding the coil is concerned you have to observe the impedience of the winding you are puting on, and you have to get some type of glue that can hold the windings in place under the heat produced during playing of the sub, also glues to reattach the spider and suspention to the fraim. in conclusion, it isnt imposiable to diy but it will take some effort in finding the right adhesives and prob isnt worth the trouble for a low end subwoofer!
Posted on Dec 29, 2009
SOURCE:
2 kicker cvr 12's in prewired kicker box with 1 wire terminal, kicker cx1200.1 amp. Whats the best way to wire this combo?
Well you really can't run both speakers on one term. because you will over heat the amp , unless your amp is rated at twice the capability of your subs , Then if so , Try positive to one sub , then neg. to the other sub , then bridge the remaining positive to the remaining negative terminal , But it is really best to get a two channel amp for your subs !!!
Sep 23, 2013 | Kicker Comp CVR 12 x 12 Car Subwoofer
How do i wire a single 12" kicker cvr dual 2 ohm
Simple power fom amo to power on sub. Ground on amp to ground on sub
Feb 28, 2013 | Car Audio & Video
I just bought a cvr kicker 10' sub, hooked it up in my car replaceing a polk audio sub. The kicker keeps blowing my fuse. i have checked the wireing. i have an 800watt sony xplode amp. Please help
i am assuming that you bought this sub used? their could be a problem with your voice coil. the voice coil moves the cone of the speaker in and out. the problem with the voice coil is that it has become lose and is doping the impedance of the sub. A lose voice coil can be cause by over powering the sub. this problem is not fix able.
Aug 01, 2011 | Kicker 01C8VR4 Car Subwoofer
I have 2 18" kicker
First you need the OHM rating of the subs. Most of the time its on the box or the magnet on the back of the subs (normaly 2ohm 4ohm or 8ohm) And that of the amp. Most amps are 4 ohm output if its a 2channel and 2ohm output if its a mono. You NEED to know these cuz wiring it wrong can blow channels in your amp or cause it to cut "in and out"
Jan 17, 2011 | Kicker Car Audio & Video
How do i wire a kicker cvr if it has two reds and blacks
the sub is a dual voice coil, and depending on how you wire them, gives you different bass response as it drops the ohms in your amp. it can be wired for 2 ohms one way 4 ohms another way or 1 ohm depending on what ohm the coils are. to learn more about this got to rockford fosgate.com, click support, then click woofer wiring wizard, this will answer all your questions about dvc subs.
Feb 10, 2010 | Kicker CVR15-4 Car Subwoofer
How to connect dual vouice coil to amp
Hey well your gonna need to give more info. is the sub dual 2ohm dual 4ohm. if you have a dual 2 ohm you wire one + to one- (like a jumper wire)and then your other +.- go to your amp as 4ohms, if you have a dual 4ohm model and your amp can handel 2ohm stereo then wire your +to+ to +on the amp and the same for your -. it will bring a 4ohms to 2 ohms by connecting pos. to pos. and neg.to neg. then to your amp.
Jan 18, 2010 | Kicker CVR12 Car Subwoofer
How do you wire 4 kicker cvr dual voice coil 4ohms to a 1500.1 kicker mono block 1 channel amp, they sound distorted when i turn them up, how should i wire them?
Hello antjobe,
According to Kicker the 1500.1 is only stable to 2ohms. So you will want your 4 CVR's to present a 2ohm or higher impedance to the amp.
The best configuration would be to wire the voice coils in series (each sub 8ohms) and then parallel all of the subs to the amp (2ohms). Here's a link to the diagram.
Hope this helps.
Jun 08, 2009 | Kicker CVR12 Car Subwoofer
I need to know how to bridge a a 4 ohm 15 inch sub down to1or2ohm
Hello solo7908,
With a single 4ohm DVC sub there are only two possible wiring solutions, parallel the voice coils for a final 2ohm load or series the voice coils for an 8ohm load. In your case, you want to wire them in parallel, both positives and both negatives connected to the amp terminals.
Here are the diagrams: (-) to (-) and then to the amp - (+) to (+) and then to the amp. Impedance = 2ohms.
Hope this helps.
Jun 06, 2009 | Kicker CompVR 12" Subwoofers/Enclosure...
Help wiring kicker cvr12's
Hello pr7met7me,
Assuming that the "old sony box" has 2 chambers with at least 1 cu/ft of internal volume each, there should be no problem running the Kickers. The CVR's are dual voice coils and come in either 2 ohm or 4 ohm versions. The coils are wired together either in parallel or in series and then wired to the box terminals.
You did not specify what make and model of amp that you intend to use. The amp will dictate how the sub voice coils are wired. You do not want to go below the minimum load that your amp is capable of supporting. If your subs are the 2 ohm version, you wire the dvc's in parallel and then parallel both subs to the amp, your final load to the amp will be 0.5 ohm and there are not many amps stable at that low of an impedance.
The terminals with the white dots are for the first voice coil. The terminals with solid-red and solid-black markings are for the 2nd voice coil. In a parallel setup, you would wire the white-dot positive and the solid-red terminals to the box internal positive and the white dot negative and solid-black to the box internal negative. In a series setup, you would run a jumper from the white dot negative to the solid-red and then connect the remaining terminals to the box terminals.
Hope this helps.
Apr 11, 2009 | Kicker CVR12 Car Subwoofer
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
Dec 10, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
447 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
