SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
SOURCE: 2000 pride celebrity sc440.
Hi donmorrill
Dosen't sound like the board at all. Sounds like you have a connection problem front to rear harness. I have worked on many celebrity 2000's and have found a bad connection with symtoms like yours. In the rear you will find where all the connections are plugged in. Check each one for continuity. Clean all connections, also make sure the little metal connectors are intact in the anderson connectors. But you do have a harness problem.
Good Luck
mimobility
Wiz
SOURCE: Pride Victory 3 electric motor will not engage the wheels.
no its definatly the kerosine mix in the fuel tank
SOURCE: electric scooter no power to motor
Sounds like the surface of the relay needs to be cleaned. Doesn't let enough juice through the connection to keep the contact. Might even just need a new relay. Or "Curtis Module."
SOURCE: scooter won't reverse and makes clicking sound by the controller by the electric motor
There is a servo which switches the transmission from forward to reverse and it needs replaced.
murf427
