Question about Toshiba Gigabeat MEGF40S MP3 Player
Please help i have a toshiba gigabeat MegF40 MP3 player which has an system error on it... every time when i turn on in my mp3 player it appears system error 0000020... i have already remove the battery and still there is a system error.. it came without manual pls help me with this problem.... thanks...
  • 1 more comment
  • nanapapa Nov 02, 2007
    Went to turn off gigabeat and blue screen with green line came up. Couldn't turn it off. waited for the battery to run out and now then charged it and turned it on, get system error # 00020002
    Please help me try to save this gigabeat.
  • Anonymous Nov 18, 2008
    i have the same system error when i ture in on then it goes to the USB as a memory i think their is problem in the mp3 system not in the hard ware
    that reason behind that how the hard disk work as a memory
    pleaseee neeed to fix this probleem
    who's can call
  • tom sh Nov 18, 2008
    Dreal all
    i have the same "systemer error" problem with my gigabeatmp3 player 40g,it appears when i turn on after 10 seconds then it appear this note in red color
    and then goes to work as USB flash memory
Toshiba Gigabeat support is 1-877-250-8595
Posted on Oct 23, 2007
SOURCE:
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
System error 00200060 NO SYSTEM FOUND ON HDD ona Toshiba MEGF40. I tried firmware upgrade, reformatting but not working hellp me
Okay, here's what you need to do. I'm assuming at some point yours like mine was formatted under windows. This is bad for them lol. Locate your copy of gigabeat room, and install it. This comes with a extra program in the start menu titled formatting utility for gigabeat. Format with this program, and then look under program files/toshiba/gigabeatroom/GBsystem. Copy GBsystem to the gigabeat, then turn the battery off with the switch on the bottom for thirty seconds. That should do it.
IMPORTANT NOTE!!!!!!!!!!!
This can only be done with a computer running USB 1.0. My newer computers could not "see" the gigabeat properly. I used an old machine with outdated USB to get mine to work again :) you can also check for aftermarket firmware called Rock Box, just installed that one mine, no more converting music to *.sat, it'll take straight mp3s now just like it should :) uploaded 20 gigs to it in less than half an hour :) beats the hell out of waiting ten hours for 8 gigs lol!
Jun 14, 2010 | Toshiba Gigabeat F40 40 GB MP3 Player
TOSHIBA GIGBEAT MEG-F20S MP3 - ERROR NO SYSTEM FOUND ON HDD
When formatting occurred a key system folder was erased - Toshiba no longer maintains the replacement software -sorry
Feb 28, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
System error on toshiba 40gb mp3 player
Try reformating the player using gigabeat format program see pg.52 owner's manual than restore the firmware data in the player see pg.51
Feb 17, 2008 | Toshiba Gigabeat F40 40 GB MP3 Player
Error number 00100060
Comment by MAHMOOD, posted on Oct 22, 2007 my younger brother plugged my megf20 gigabeat to pc and he formatted that using windows xp format disk utility now when i am turning on the gigabeat i just see an error and that is
no system found on hdd
error number is 00100060
if you can help me please
Oct 22, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
MEGF40
Oct 19, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Owners manual
Hi! Dear I have Owners Manual I can email you Also can you explain me how to open Gigabeat to remove battery and HD Please email me at [email protected] I will attached manual once you provide me your email Thanks Jitu
Sep 01, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
System error 0000020
1.U need to reformat player first: see page 52 of owners manual(application software) 2.when formatting with gigabeat finished u need to restore of the firmware data see page 51 of the manual. Piece of cake,dude!
Aug 02, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat MEGF40S MP3 Player Logo
149 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
JohnLong
Blake Whiteside
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
