My weber grill silver will not get hot over the test heat
Since I was not familiar with the term you used "will not get over the test heat." I took a look at the Owner's Manual for you model grill. The only reference I could find to temperature was in the section about preheating the grill to 550 degrees F. That being the case, I guess that's what you may have been referring too.
To solve this problem do the following, as I believe falme heights on the Highest settings are not what they should be.
First, check the gas line hose from the tank to the grill. Look for kinks or twisting that would restrict the flow of gas to the burners. If you find any, turn the gas tank valve OFF, disconnect the hose from the tank and straighten the hose, before reconnecting it to the tank. Then open the gas valve Very, Very Slowly, until it's fully open.
If you didn't find any kins ot twist, do the following:
1. Turn the gas tank valve OFF, Disconnect the hose from the tank and wait 5 minutes.
2. Turn on any pair of burners to High for io minute and then turn them OFF.
3. After 5 minutes has elapsed, reconnect the hose to the tank.
4. Open the tank valve VERY, VERY, SLOWLY (Slow motion, slow) until it's fully open.
5. Light the burner farthest from the tank first and turn it to HIGH. Does the flame height look
correct? If so, light the remaining burners the same way. Do all the flame heights look correct?
If so, you solved the problem!
6, Close the grill lid and allow 10 - 15 minutes for the grill to preheat to your desired temperature.
If the above didn't solve the problem. The problem, may in fact be a faulty Thermometer. To test it, invest $5.00 in an Oven Thermometer, like you use in a regular oven, that will sit on the oven rack. But, in this case will sit on the cooking grates.
Set the thermometer on the cooking grates, light all the burners, close the lid an allow the grill to preheat for 10 minutes. Then read the temp on the grill thermometer, open the lid an compare it to the Oven thermometer on the grill grates. I'm willing to bet, the oven thermometer will read higher. That's because, it's right down on the cooking grates and not reading the air temperature, like the grill thermometer is. That's why, I all ways use an oven thermometer on my own grill. It's more accurate.
Hope this helped you solve the problem. Please let me know and Happy Grilling.
