Question about Grilling
Jenn Air gas grill with cast iron burners...only ignite on one side of burner...other side ports will not ignite...but will ignite right away with lit match...all three burners do this...
  • archuready Apr 20, 2009
    same problem...
  • Anonymous May 23, 2009
    perfect solution
    thanks
It sounds like your cross-over **** located underneath on the back of the burner is needs cleaning. Take your burner out, turn them over and your will see a slot on the rear of the burner. wire brush the slot until it has a clean ****. This cross-over **** is what brings the flame to the right side.
Posted on Apr 27, 2009
Jenn- Air rotisserie burner wont lite. Doesn't
Try removing the cover on the back of the grill hood and finding the orifice for the rear burner. Check to see if the orifice is plugged.
Jul 31, 2011 | Jenn-Air Grilling
Lights but does not heat up beyond 250degrees
If this is a propane grill, try replacing the regulator and hose going to the tank. When a regulator is failing, it allows gas to pass, but not enough to allow the grill to heat up properly. If this is an older grill. You can also check each burner for blocked gas ports. Just a few blocked ports in a burner can prevent the burner from lighting completely, or from moving from one side of the burner to the other.
Jul 03, 2011 | Jenn-Air Grilling
Need help re: replacing igniter of Gas Grill
If it is like mine, you have to remove the front control panel on the side burner and the front of the side shelf. Remove four screws behind the fronts below the shelf/burner and then you will have access to the screws to remove the main control panel. Be careful with all the hoses and gas piping. If the electronic ignitor is melted like mine(i am on #3), you have more problems than the igniter. I had to replace the burners and the gas valves to stop the flame from "backing up" into this area. Hope this helps.
Jul 10, 2010 | Jenn-Air Grilling
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Vermont casting ignitor dont work install new new button and batteries
igniter to burner gap on 4 burner jenn aire 480 (vermont casting built} gas grill
Apr 19, 2009 | Vermont American Tool Company VM600BSP...
Jenn Air Grill - Gas flow from one valve
I have the same problem. The middle and the right burners will work, but if I light the left side (3rd burner) all 3 go out. pressure is reduced to zero.
Aug 30, 2008 | Grilling
Burner replacement
If you ermove the control panel on the fom you should be able to slide the gas manifold back a little thus putting the nozzle into the burners.
The manifold has a couple of screws at the sides
Jul 29, 2008 | Viking VGBQ410-3RT Grill
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Grilling Logo
888 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
