Question about Craftsman Convertible 25cc. Gas Line Trimmer
Craftsman 4 Stroke Trimmer
I cannot get it to start, I have spark, fuel seems to be also present, there is compression, i give it a small shot of ether and it still doesn't even pop over, WHAT ELSE?
  • nemfeely21 Apr 27, 2009
    But why does it not even pop over when i give it a shot of ether?
  • 37 Answers
Make sure fuel is fresh and carb is tuned (there are adjustment screws that are "locked".. illegal to unlock, but can be done.
Posted on Apr 19, 2009
I have a 1994 ford escort and it's not getting eoungh power I've change the battery, sparks plugs and the alternator don't know what else to do please help
Did you check the timing? If the timing is off there will be a reduction in performance and power will be greatly reduced. If the engine is "pinging" or "knocking" under heavy acceleration, your timing is advanced, and pre ignition is occurring (that's when the spark has ignited the fuel in the combustion chamber prematurely), resulting in a knocking sound. When the piston is compressing the air/fuel mixture within the combustion chamber, the spark plug produces a spark from current it receives from contacts closing in the distributor cap. (Where all the spark plug wires are plugged into) if that spark come BEFORE the piston finishes it up stroke or compression stroke, the piston is then being slowed down from the kinetic energy produced by the exploding fuel. Thats where we loose our power. Idealy, the spark should come AFTER the piston has rotated over the top of its stroke, It has reached its limit in compression and is on its way back down then the spark should ignite the compressed fuel, thus giving the piston an additional "shove" back down to start its "Power" stroke, once its reached the bottom of the power stroke (stroke #2 of 4) it is then carried back up for the "exhaust" stroke pushing the burnt fuel out of the combustion camber and into the exhaust manifold, one it has reached the top of that stroke it begins its journey back down to start stroke number 4, the Intake stroke. Drawing in air/fuel mixture to again be pushed back upward to compress the air/fuel, and repeat the process over and over again. Now that I have thoroughly bored you to tears, Yeah, check the engine timing, if its not the timing it may be a vacuum leak.
May 11, 2015 | Ford Cars & Trucks
It is getting fuel but has a weak spark and will not start.
DO NOT , I repeat do not use starting fluid on a 2 stroke chainsaw or trimmer. you will score the cylinder or the piston. When trying to diagnose a hard to start motor just give it a small squirt of mix in the carburetor. If it won't fire you have a compression problem or an ignition problem. when you test for spark make sure you have a good plug, that is well grounded and not in bright sunlight which can make it hard to see the spark. if you have spark, do a compression test.
Mar 19, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Managemylife.com sears
You need three things. Spark, compression and fuel. Pull the spark plug and make sure it is not fouled and you have spark when cranking. Put your finger over the spark plug hole and feel for compression while pulling the engine over. There is a reed valve between carb and block that clogs and prevents fuel from getting to cylinder.
Aug 15, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Kohler Command 12.5 OHV engine on John Deere STX 38 will not start. Engine spins at a high rotation rate but will not fire. Spark is present at plug. Suspect automatic compression problem but not sure how...
Have you tried pouring a little fuel into the plug hole and try for start? If it runs for a short time, you have fuel delivery problems. Check the fuel filter for plugging. Look under the carburetor bowl for a small solenoid that commonly sticks in one position. I'm not aware of an automatic compression release on these engines. As this is a 4-stroke engine, it's possible that one of the valve clearances has closed up during use. Check this with the piston at top-dead-center on the compression stroke. Hope some of this helps!
Sep 18, 2010 | Kohler CH25 PA-CH730-0040 Command Gasoline...
2003 crf 4 stroke. has compression. no leaks. engine sparking. fuel system fine, plug wet. engine wont start?
Gotta start with the simple things...
How do you know the compression is fine? Since you did not give a compression reading I do not know what method you used to test the compression.
How do you know the fuel system is fine? The plug is wet with what? Could it be water?
How do you know the spark is fine? Have you used a spark tester? Or did yuo use the spark plug on the side of the head? Did you know a bad spark plug can still spark under regular condition but wont spark under compression?
You left out valve timing- its a 4-stroke.
First put in a new plug. Then see if it hits on a prime ( see my tip on diagnosing a small engine).
If you have double checked all the basics and are sure we have fuel,compression, and ignition and it still wont start then check your flywheel key and valve timing.
Jan 02, 2010 | 2003 Honda CRF 450 R
I have a gas operated 31cc Craftsman model number 316.798221 weedwacker trimmer 17 I mixed fuel with 2 cycle engine oil using a 4 to 1 ratio. The trimmer no longer starts. It seems as if it is about to...
If you have mixed your gas and oil to a 4 to one mix you have way too much oil in your gasoline. Drain out your fuel tank and carburetor. ----------------------------------------------------------------------------- Remove the spark plug and clean if necessary. Mix your fuel in a fuel container at 40 to one. Some sites even recommend a 50 to one mixture. (50 to one mixture is one pint of oil to 6 gallons of gasoline) Refill your fuel tank on the trimmer and try to crank, if it does not want to crank within 4-5 pulls then you may want to give it a very small shot of starting ether in the carburetor intake and try to crank again. Good Luck, I hope this helped, Please rate me, Thanks
Dec 30, 2009 | Garden
What causes a 2 stroke engine to have too much compression and therefore difficult to pull the recoil starter?
Nothing will do this...what is most likely the problem is either the recoil is going bad or you have the wrong spark plug installed.
Dec 03, 2009 | Toro& Electric String Trimmer
One year old Ryobi s430 4 stroke trimmer will not start.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 19, 2009 | Ryobi Garden
Craftsman trimmer won't start
Let's start with the easy stuff first. Remove and clean the spark plug. Look into the tank and fish out the fuel filter. It should be stuck in the end of the fuel line in the tank. I usually use a short piece of coathanger with a small hook bent into the end of it. Clean or replace the fuel filter. The next thing is to clean the small screen at the exhaust. Remove any carbon build-up there that you can. Sure hope this helped and best wishes.
Aug 17, 2009 | Craftsman Convertible 25cc. Gas Line...
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Convertible 25cc. Gas Line Trimmer Logo
449 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
