Question about Bernina Artista 180
How to identify a bernina sewing machine
Have an old bernina machine,know nothing about,was first wife's grandmothers.both deceased.
  • 19 Answers
Older machines, the model number is found on the throat of the machine and sometimes stamped on the cover over the motor. You can also give me the serial number stamped on the machine and I can look it up for you. I am a certified Bernina/Brother dealer and technician.
Perhaps look at Ebay, you may get lucky before your eyes become crossed looking at the many many Bernina models out there.
Posted on Jan 08, 2009
  • Bernina Master
  • 12,731 Answers
If it's a Bernina from a deceased family member, it is probably a good model to have. The old Berninas, if well taken care of, are much sought after machines. I have a few myself, and they are awesome...totally mechanical. When cleaned and oiled regularly, they are workhorses.
Posted on Apr 02, 2015
  • Bernina Expert
  • 121 Answers
Re older BERNINA usually on the front or inside the vertical column on right is the model number
the age can be determined by the serial number
the early models started with the first two numbers indicating the year of manufacture. Eg 58 indicated made in 1958
or 65 -1965
then they changed to a numbering system
if it began with a 1. It was made in 70's second number the yr
eg 12 -1972; 13-1973, 17- 1977
the 2= 1980's and lime above 22=1982. 26= 1986
then 3= 1990's. As above
hope this helps contact me for more info if needed
Wayne
[email protected]@shaw.ca
Posted on Apr 01, 2015
  • 32 Answers
Try www.sawing,com
Posted on Oct 17, 2007
SOURCE:
How to remove the top cover of Bernina 830. My machine keeps telling me to rethread. It stitches about 10 stitches then stops
Which Bernina 830 are you referring to? (Yeah, it was crazy of Bernina to use the same numbers to identify different models...). There is the old Bernina 830 Record and the new computerized Bernina 830.
Have you tried rethreading the machine? If so, be sure to ALWAYS RAISE the presser foot. Verify the thread path is correct.
Apr 10, 2018 | Bernina Sewing Machines
Bernina Record 730 - made in 1965ish. Recently he has started sewing very slowly although the bobbin winder worked normally. We cannot find out why this is happening.
Oh, no! Do NOT give up on your oldie but goodie! The symptoms are common with older mechanical machines. These machines are wonderful and deserve to be given another chance. Most often, the old oil solidifies and causes the moving parts to seize. With persistence, patience, and a couple of very simple supplies, many of these machines are happily sewing again. The secret is a combination of Tri-Flow and heat and making sure that "all" the moving parts get lubed, even the stitch levers and dials. I have resurrected several older Berninas using the following technique. Several completely seized machines required multiple repetitions over a period of days. If the machine does not have any cracked gears, most likely it can be made worthy again and make your grandmother proud that she gave you such a lasting, wonderful gift.
Resist the temptation to try to run the motor until the machine has gone through a thorough "treatment" and is moving freely manually. Once the machine is moving freely, you will rejoice at the happy and satisfied sound it makes!
Good luck with your lovely!
Wheel on right side that controls the needle up and down is very tight...
How can fix stuck needle bar on my Bernina 730
Nov 28, 2016 | Bernina Sewing Machines
I just received this machine from my deceased grandmother and I don't have A MANUAL ON IT .tHE SERIAL# IS c10091651
Search the internet for:
Make + Model + the word "Manual"
or contact the manufacturer.
Apr 03, 2016 | Sewing Machines
My needle is not movin up or down..switched to zig zag and it moved left and right but no up and down..Im lost without it..whats wrong and how do i fix it? Bernina 1090 s
Have you oiled your Bernina recently/regularly? Consult your owner's manual under the Maintenance section. Sounds like the old oil may have dried and is prohibiting the needle bar from moving. Use good quality (ie Bernina) oil, not 3-in-1, WD-40, cooking oil, or the sewing machine oil from your grandmother's sewing basket). To help free it up, direct heated air from a handheld hairdryer into the interior mechanism of the machine, concentrating on the needle bar area.
Aug 19, 2015 | Bernina Sewing Machines
Bernina 180 sewing machine 'died'. Was sewing - everything OK. Stopped to turn material, looked away, and when I turned back, screen, machine, everything was dead. Power source is OK. Exchanged cord -...
Hi, sorry to say but very rarely is it the fuse when this happens. You can unscrew the one screw on the ouside and pop the cover open. (carefull as there are wires attached and make sure you are grounded or have discharged any static from yourself).
The fuse will be self-evident but I suspect you will need a visit to your Bernina dealership for a new circuitboard.
Rick
Certified Bernina tech
Dec 06, 2009 | Bernina Artista 180
Bernina 1090 only sewing backwards
1.Turn the bobbin winder off.
2.You have to reverse the wires on the carbon brushes.
3.Make sure that you have the needle in correctly- with the flat side to the back. Those machines rarely go out of time.
Jul 22, 2009 | Bernina Sewing Machines
Older Bernina
Hello Laurie
If you are still looking for a free of coast manual for the Bernina 530 (530-1 and 530-2 are idendically in handling and using) I can send you the free link.
With regards from Switzerland
Romeo
mailto:[email protected]
Sep 25, 2008 | Sewing Machines
Sewing Machines Logo
572 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
