Question about ASUS Eee PC 900 Notebook
ASUS eeePC Netbook mouse key "melted"
I purchased the eeePC 900 netbook. Within 24 hrs the unit had had a heat issue that cused the RT side of mouse key to "melt". Subsequent pressing bent the key in on the right. ASUS and Best Buy both refused return. Worst Buy Freek actually had the nerve to suggest I did something to it. DUH! I turned it on! This seems to be a cooling issue. Is there a fan and does it actually work? Is this unit just defective, as is the non existent customer service at Best Buy and ASUS or are the netbooks prone to this cheap mouse key issue and overheating?
My ACER netbook, which works like a dream, make this look like garbage. Now I'm out money and very unhappy with Worst Buy as well as *****. Any suggestions?
My asus 1001xd Netbook Cant Detect My Built-in Webcam On My Netbook
there is a tiny cable that attaches to the camera module. most average people cannot repair it, but if you are careful, it is not hard to repair. The most likely issue is the cable has simply unplugged from the camera module. Most modules look like the one pictured here. There is usually a small cable on the side or bottom and re-inserting it will usually fix it, or if you cannot do it, one of your computer savvy friends could do it.
Nov 21, 2014 | asus-tek Asus Netbook 1001PXD-MU17-BU...
My netbook escape button stops working, what shall i do?
the keyboard is a matrix, if any button won't work that means a poor contact in this button, try to clean it, if steel not working you have to change the whole keyboard. it cost about 10 $:
New Keyboard for Asus EEEPC 700 701 900 901 Series V072462BS2 Black US
Feb 14, 2014 | ASUS Eee PC 900 Notebook
Asus eee pc 900 netbook will not boot. Error message says remove disks or other media press any key to restart
Hi guys, i hope this could bring little light to this boot-stop error. First of all sorry for my english /slovakia/. So thi applies for asus eeepc 1005HA /maybe some other models too - depending on motherboard construction. In my case it was 2 parts motherboard which were conected via flex cable. Both parts contrains USB ports which is the think what stops you access to BIOS and all functions. If you hit TAB button during start up /best way to do so before pressing powerbutton/ you will see post messages, which stops on inicializing USB controlers. So what you need to do is
1. turn on computer
2.unplug flex cable which leds to usb ports
3. now you should see progress on your screen, so go to BIOS /F2/
4. visit ADVANCE tab
5. visit ide onboard configuration
6. check for usb controler configuration
7. mark it as DISABLED
8. hit F10 to save your settings
9.reboot
after this hint you will have full access to all functions like before, USB ports included.
hope this little research hlep u too, my eee1005HA is now glowing
May 03, 2012 | ASUS Eee PC 900HD Netbook
I have a Eee PC series 900 and onll like 4 or 5 keys do not want to work . . . what can i do to fix them ?
You will have to most likely purchase a new keyboard for your laptop i have attached where u can buy it from amazon but be sure of the model of the laptop which model do you have?
model number can be found located normally under your laptop look for where u see something saying Eee Pc and model
http://www.amazon.com/Black-Keyboard-Asus-EEEPC-Netbook/product-reviews/B001MW5FQY/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
Feb 26, 2011 | Computers & Internet
How do i change my background image on the asus eee netbook's desktop?
Unlimited research shows that if you have Windows 7 Starter on your asus netbook it won't allow you to customize it, which sucks because I didn't know that until I got home and tried to change it -____- (i have the same laptop & same issue)
Dec 25, 2010 | ASUS Eee 900 Netbook
How do I unfreeze my touchpad on my eeepc netbook
you might be able to adjust some settings using your "tab"or arrow keys failing that re-install OS and/or clean reboot including discscan if you can
Sep 04, 2010 | ASUS EEEPC1000H-BLK066X NetBook Intel Atom...
I have an asus eeepc 900. i have an error message
hi charmed4031this netbook comes with an internal harddisk on which windows is installed but lacks any optical drives so far.
You will have to get an external CD/DVD-drive plus a Windows-CD for it from which you safely can reinstall windows or replace the missing file. Please find out which windows version you are using(Win200, Win XP Home for e.g.,), lend or buy this external drive, connect devices and let the computer work it's magic, if still facing diffifculties, you know where to find us ;-)
Sep 18, 2009 | ASUS Eee PC 900 16G Notebook
Audio for asus eee pc 900 doesn't work
Hi thus your eeepc is still under warranty? Your eeepc comes with a recovery CD. But the problem is that laptop have no CD rom drive. You have to buy a CD rom Drive that you have to connect to usb, or you have to go to fry's and buy this tools deluxe usb 2.o to IDE cable for 2.5/3.5/5.25 drive with power adapter. find an old CD rom and use that so you can use the recovery CD that comes with the laptop. or you can do this copy that recovery CD to a 8g usb memory stick. them connect it to you eeepc. Hope this info will help you solve your problem.
HH
Aug 21, 2009 | ASUS Eee 900 Netbook
Netbook touch pad quit working after attaching a USB mouse
Go into the mouse options in the control panel and make sure that the touch pad is not disabled.
May 31, 2009 | ASUS Eee PC 900 Notebook
ASUS Eee PC 900 Notebook Logo
162 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
