Whirlpool AWM 1403 1400 Spin
My washng machine goes through its cycle until half way through K. It doesn't attempt to rinse and spin or finish the programme off, ie 1,2, 3 and 4. It doesn't use the fabric conditioner and the water stays in the machine drum even after trying to move the programme on a bit. I have checked for blockages and all is ok, water is going through hot and cold pipes. The belt is fine too. Please help me.
SOURCE: Fabric conditioner drawer does not empty
Hi Andy, its not a cure for the conditioner drawer but it is not as bad as it was. I gave the roof of the drawer slot a good clean with a long brush and some hot water. I used my greenhouse sprayer as it has a longish lance and it could get into hard to reach spots. Give it a go, nothing to lose. Let me know.
Posted on Jan 17, 2008
kakee
  • 1269 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
That's a timer problem. Check on the user's manual on how to reset the timer settings. The timer can be replace if found defective but you need a pro technician to do it.
Posted on Aug 29, 2008
SOURCE: Bosh 1200 classixx does not finish the program, conditioner stays in the dispenser
I have cleaned the pipes going for rinsed water,plus the plumbing stuff like vertical pipe which has on top something like coupler for washing machine and dishwasher, here was problem. It was cloged up with rubish and becouse the pump could not make enugh pressure the machine has stopped in the moiddle of washing as it could not rinse.(Spin)
cheers
Posted on Sep 28, 2008
mumma_1
  • 903 Answers
SOURCE: candy washer dryer 1400 spin cmd 146
try taking the soap dispenser draw out a give it a thorough clean inside and on the underneath of the drawer, then clean inside the machine where the drawer fits into. Sometimes a build up of detergent/softener can cause this.
I hope this helps
Posted on Jan 19, 2009
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
Posted on Apr 25, 2009
Our whirlpool wfs1285aw doesn't seem to be spinning and drying out clothes enough when Finished. The clothes are still drenched. Any ideas how to rectify this? Is there a filter that needs cleaning?
the rinse section spins slow while the rinsing is in process as this does 2 things
spreads the water through the clothes for a proper rinse
spins slow to equalize the cloths around the bowl
when the rinse cycle is finished and the tap is shut off it goes into a high speed spin
Your problem sounds like the program is not going to the high speed spin cycle and that would indicate a problem board
call a technician for a proper diagnosis and quote
Sep 15, 2016 | Whirlpool Washing Machines
Why won't my whirlpool model #LSR8233JQ0 go through the rinse cycle or the spin cycle
i have no info on this model, but if its a front loader then you will be looking at your drain pump motor as at the start of the rinse and spin cycles it will need to drain if it cannot it will not even attempt to continue on, so take that little drain pump cover off and have a look inside the propeller it may just be jammed up, if not it may be blocked somewhere along the hose or just a faulty pump altogether, if its a top loader you will be looking for the same thing but if it isn't the pump it will be the lid switch that senses the lid has been shut as all whirlpool top loaders must be able to activate the lid switch or else it cant spin (simply a safety feature to prevent injury), get back to me if you have any questions
Nov 21, 2011 | Whirlpool Washing Machines
Maytag MAH8700 AWM will not spin during rinse cycles
As you said in the question you are washing machine need to get services during rinse washing machines should spin.Try selecting only rinse option only.If it does not spin means just services it will be fine.Thanks for you are question.
Jun 17, 2011 | Maytag Washing Machines
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Washing Machines Logo
211 people viewed this question
Top Washing Machines Experts
