Question about Home
Hushflo valve i have a hushflo toilet valve that continues to pump water out even after it is full should i just replace the whole unit and get a new flush valve
  • Anonymous Mar 17, 2014
    unit runs sounds like water runs back into unit pumps again. is there a check valve in system?
    Problem Solver:
  • 16 Answers
Fluid masters are cheap and available every where i would just replace it
Posted on May 03, 2009
Cistern
The arm controls the Flush Valve. Inside the flush valve is a black rubber "seal" that closes the end of the fill pipe and stops the water. If a piece of sand, grit, or small rock gets imbedded in the seal it will allow water to pass through even when the tank is full. Either you take apart the flush valve and remove the grit, or you replace the whole valve. Sometimes even when the grit is removed the rubber seal is damaged and must be replaced. A new valve, and some of these replacement seals can be purchased at a good hardware or plumbing supply store. Use the valve handle, below the tank, on the pipe that comes through the wall, to turn off the water before replacing the seal or valve.
May 26, 2013 | Home
Fill water squirts out "vents" at top and even
replace the valve rubber at the top of the inlet control
Sep 06, 2017 | Kohler Toilet - One Piece with Ingenium...
The pump in my unit continues to try to pump.This happens around every 30 seconds
The problem is the non return valve probably at the elbow end of the unit. If it is a new unit then i would say the rubber has not been installed and if it is an old unit the rubber has probably become dislodged
Oct 07, 2010 | Saniflo & Saniplus& Macerator Pump
I have a saniplus toilet, the macerating unit runs about every 2 minutes for 1-2 seconds at a time. I'ver replaced the flapper and even turned off the water to the unit and stopped using it, but it keeps...
Water pressure makes the unit kick on and off. Water could be leaking from the toilet tank into the bowl and from bowl into the pump. Or the check valve inside the discharge elbow (on top of the lid) may not be sitting properly or is being obstructed causing waste water to leak inside the pump, creating enough water pressure to make the unit kick on and off by itself.
Sep 06, 2010 | Saniflo & Saniplus& Macerator Pump
Hushflo anti-siphon toilet valve will not stop filling.
make sure the float is not stuck or if it doestn't have a float move the head on the unit around sometimes they stick
Aug 11, 2010 | Home
Toilet bowl, and pump housing are full, drain pipe clear? pump not running correctly. how do i drain it to get acsess to pump?
Prepare to get dirty. Use a mug with a handle to lift the water out of the toilet bowl into a bucket. Reduce the water level until it stops increasing from the backflow from the Saniflo. Disconnect the electrical connections (isolate the unit first) Disconnect the outflow pipe but be prepared for some spillage from any vertical pipe in your domestic installation. Ease the boot off the WC soil pipe, Disconnect any breathers. Slide the unit out from behind the toilet but maintaining a backward tipping angle to prevent water inside the unit from spilling out of the boot. Take the whole unit outside, keeping it tipped backwards. Take the lid off, noting how the seal is oriented for reassembly. Use a high pressure garden hose to clean out the interior and inspect. Check the rubber diaphragm on the bottom of the sensor unit. These develop corrugations and become slack over time. If so it will have insufficient power to depress and release the microswitch within the sensor unit. If your unit filled the toilet bowl with soiled water and the pump kept running, it is likely that the non-return valve beneath the outlet pipe is faulty. On some models the valve is Y shaped and the branch of the Y is a rolling ball that falls by gravity when the pump switches off. Replace the valve. If your unit kept running but with clean water in the bowl, it is likely your diaphragm is faulty. Check for corrugations and make sure it is no longer caked with accumulated solid waste. If you cannot buy a new sensor unit complete with diaphragm, you may need a new Saniflo. Both of my Saniflo units stopped working satisfactorily after 10 years. My German built unit has now been working without fault for 19 years.
Apr 25, 2010 | Saniflo & Saniplus& Macerator Pump
Toilet refills and water stops running. a couple seconds later get the sound of air which continues. if I push black float down a bit it stops manually but when I let go continues??
It can be one of two things first you either have air in your watter line in this case let water run for a while and see if you get air if so let it run until it quits spitting or contact your water company for help.Second the diaphram is worn in the top of the valve in this case the whole valve will need to be replaced turn off water flush toilet put pan or bowl under water line at toilet remove water line at toilet .Unscrew the fitting and remove hose next remove the large plastic nut on the bottom of tank .Some water will leak out hence the bowl! remove valve replace wit new one line up in same direction it was removed put on new rubber washer supplied,Tighten plastic nut replace hose and tighten turn on water that should fix it!
Nov 11, 2009 | Humidifiers
The tank no longer fills with water so the toilet doesn't flush. Unit has been problem free for almost 10 years. Water supply valve in the back opens and closes. Simply quit.
it's probably your fill valve has gone kaput! try replacing that. turn the water off disconnect the water suppily line and there should be one nut under the toilet tank and then the whole valve should pop right out and you can pick up a new one . fluidmaster makes the best one! and just follow their instructions on installing it.
Aug 02, 2009 | Kohler K-3384-2 San Raphael Elongated...
PLUMBSHOP HUSHFLO #516 Toilet anti-siphon/valve replacement Kit- The tank continues to fill very, very slowly after shutting off. Can the valve be cleaned? I have sediment problems with grit in the...
Usually, there is a diaphram located at the needle valve that can be removed and cleaned and or replaced. If you know you have grit in the water, then you are right, that will cause problems with the fill valve not fully closing.
Mar 07, 2009 | Home
Home Logo
1,273 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
