Your problem is electrical, check all your grounds and make sure they are clean and grounded well, check your alternator out to see what its charging under a load, and that the regulator is working properly. Check the main wire from the starter to the alternator and make sure it is clean and tight, and that all is grounded, clear codes and try again
First i would check the alternator just to be on the safe side sounds just like the problem or the brain or body control module went haywire on and sometimes a battery will show that is good untill you actually use it might get a good diagnose from a local shop - dealer etc.
SOURCE: dash cluster lights on
Most likely its thr rear toner ring part only costs about 40 dollars if you can do it yourself or pep boys will do it for 120 Just get under back of truck and look at end of axle there is something that looks like a gear wheel for a bycycle if its missing or you can move it with your hand that is the problem 99% sure thats what it is dont let the dealer rook you they wanted to charge me 690 for new axle and it wasnt necessary
SOURCE: Ford 2005 E350 econoline van has had a battery light problem
you have a voltage drop.fine the damaged wire going fro mthe positive terminal of your battery to your alternator.fix this or it will keep working the alternator and draining your battery.
SOURCE: 2003 Ford Focus battery light is on, but alternator appears good
Disconnect battery ground for 30 seconds & reconnect. Light should be out unless you have deeper diagnostic problem. Charging system good Battery good. This action should reset trouble light. Good luck!
SOURCE: 95 F250 not starting
You said you tightened the battery cables, did you check the other end of the negative where it bolts to the engine. When you tightened the cables you also used a battery brush and cleaned the posts and ends?
Testimonial: "thank you"
SOURCE: my battery light came on dash of ford transit
yes looks like either u need to charge or change ur battery.
