Question about Hotpoint Aquarius WF000 Front Load Washer
Belt on a hotpoint wf250
How do you fit a belt on a hotpoint wf 250
  • redwilkinson Apr 19, 2009
    there does not seem to be a tensioner on cant move motor to loosen the belt
In case anyone needs to fit a belt to the WF250 I got one on - eventually!
There is no tensioner, the motor is held in place with fixed bolts so the system must have changed after all.
After trying in vain to fit the belt I got it on with the help of two strong cable ties.
Tilt the machine over so the weights take the drum away from the rear of the machine giving more room for access. Put the belt over the motor spindle and feed it anti clockwise around the drum til it stops. Looking down from the top use a cable tie to fix the belt at around the 11 o'clock position. Pull it round further (is tough) so the cable tie is around 1 0'clock and fix another cable tie at 11 o'clock position. Pull round once more and the belt will jump on. Turn it all back and remove the cable ties. Check the belt position is good and not slipping down between drum.
Posted on Oct 05, 2012
  • 297 Answers
Open it up, see wat thensions the belt, loosen that up and fit new belt. retension
Posted on Apr 19, 2009
  • astrid prieto Apr 19, 2009
    there is always a way to tension. so don't rate me inapropiate.
    look again. Or the motor can slide or revolve. whatever.
    I am doing this 30 years. the system has not changed over 150 years.
Wf250 will only allow a very small amount of water in and then shuts off.
Check the lint screen and water outflow from inside the tub cylinder... socks are often lodged inside the tube. Check the filter screen on the inlet hose at the faucet (tap).
May 29, 2015 | Hotpoint Repair Pcb / Module Wf240 Wf250...
How do i fix a noisy spin cycle on hotpoint wf250
Hi.
A noisy spin cycle is usually because the bearings are rumbling and/or collapsed.
Unfortunately this is not a simple job and would require a service call and probably a workshop.
Good luck.
Nomess
Sep 28, 2014 | Hotpoint Repair Pcb / Module Wf240 Wf250...
Have a Hotpoint WF250 washing machine. Fitted new door lock switch, but door lock LED now constantly flashes & washing cycle does not start, even though water pump clicks!
TRY CHECKING YOUR MOTOR BRUSHES.IF THEY ARE OK IT IS PROBABLY THE PC BOARD LOCATED AT THE BOTTOM RIGHT OF THE MACHINE AS YOU LOOK FROM THE FRONT
Jun 05, 2013 | Washing Machines
Can a HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN washing machine run off a cold fill only
The simple answer is yes, via a Y piece if it is a hot and cold fill model
The fitting is available from B&Q, or a plumbers merchants
Aug 13, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Fitting pump to hotpoint WF250
disconnect the machine hoses and all drain put it on its side you will see the pump usually help in place by 2 screws/ 2 hose clips/ 2 wire thats it pump should cost no more than approx.18.00
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius wf250 won't do anything it lights up with wash symbol but doesn't fill or wash it doesn't make no noise or anything please help
open the top of washing machine and near the door on right side is a connector loose just push in and will work fine.
May 10, 2009 | Washing Machines
Hotpoint wf 250 aquaries
try changing your water valve this should sort problem
Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
May 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
230 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
