Question about Brother HL-5240 Laser Printer
My printer will not print, it is a Brother 5240
I have checked all connections, there is no paper jam, there is ink and we have even reinstall it and it still does not print.
  • coffeebeanie May 17, 2009
    My Brother 5240 erratically stops printing, but is showing an online and ready. Running Vista Home. Reinstalling it doesn't help, nor does turning off/holding down buttons turning on.
Soulvisitor
  • 1113 Answers
SOURCE: Brother 5240 laser printer changed toner still wont work.
When a brand new toner is inserted it has a switch that is activated when new cart is installed.
Machine has two toner light errors blinking is toner low, full on is toner out all stop,
 I guess yours has not reconised new cart, was it new out of a sealed box?
If so then it failed to reset upon install
You can pull apart reset lever on left front of cartridge and reset to original position if you want to get just a little tecnical
One sctew carefull gears fall off ,white lever needs to be fully to rear of slot to emulate new cart status..
If brand new cart return to supplier as faulty.
If you just refilled it, go buy a real one to prolong life of your product
Posted on Oct 20, 2007
SOURCE: 5240 brother
-Turn Power Off
-Open Front Cover
-Hold down "Go" and "Job Cancel" Buttons while turning on Printer (All lights will stay on)
-Press "Go" button 2x
-Press "Go" button 5x
-Close door and Print
Posted on May 22, 2008
celibytes
  • 70 Answers
SOURCE: My Brother Printer (model MFC-290c) and ink
On your printer take a look on the "ink management button"press it then look for cleaning using the arrows up and down then press ok or set or what ever the command the printer will display just try to perform head cleaning.try for several times lets say 4x don't clean too much it might ruin all other color if it has no changes try to bring it to a service center,they can soak it to a chemical solution,the head is clog.
Posted on Sep 10, 2009
Semi-Driver
  • 434 Answers
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
Posted on Jan 21, 2010
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
HOW TO PRINT ENVELOP IN BROTHER HL 5240
straight paper path. take out tray and toner.. pop down back the paper will be in one of the places.. check for nicks or damage to leading edge of the paper. If its labels get back to us.
Jul 26, 2014 | Brother HL-5240 Laser Printer
My Brother HL-5240 printer constantly has the paper light on even though there is paper loaded
You probably printed a document that was forced to the manual feed. Place some paper there and it should print. Go to your printer preferences and set the default tray to tray1 instead of Auto.
Jan 31, 2011 | Brother HL-5240 Laser Printer
Paper jams just before it comes out. Complete image has printed but the page doesn't "come out", gets jammed. If doing 2 page print usually only half of the second page will print as it backs up behind 1st...
This sounds like a classic fuser failure. Take the printer to a qualified repair facility and they can replace the fuser and check all of the fuser and exit drives for proper operation.
Jun 16, 2010 | Brother HL-5240 Laser Printer
Yesterday I was printing 4 pages from my office to the printer at the front desk. I did not realize that someone had placed a book on top of the printer and the last page never printed. The 3 pages printed...
There is a sensor that goes up when printing and should go back to its normal position after ejecting the printed page. Sometimes it get stuck, you can manually reposition that sensor. It looks like a small plastic lever and located where the paper is going out.
Jan 14, 2010 | Brother HL-5240 Laser Printer
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the light turns green. however, when i print a file, the file goes into the print queue for a few seconds then...
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Nov 25, 2009 | Brother HL-5240 Laser Printer
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Office Equipment & Supplies
New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Jul 22, 2008 | Brother HL-5240 Laser Printer
Black Lines
you need to change drum
elvis
Apr 18, 2008 | Brother HL-5240 Laser Printer
No longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Apr 01, 2008 | Brother HL-5240 Laser Printer
Paper jams
The Pickup roller of the printer is not properly aligned, send the printer to repair and see the jam
Sep 29, 2007 | Brother HL-2040 Laser Printer
Brother HL-5240 Laser Printer Logo
154 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
