Question about Kenmore 92002 / 92004 Kitchen Range
Oven element Model 665:95792000 The broiler element comes on and stays on when everything is turned off, Can only turn off by unplugging or throwing breaker. Any ideas?
  • Anonymous Mar 24, 2014
    breakers are working
    President:
  • 878 Answers
Model T, either you have a stuck or shorted broil keypad or the relay on the board is welded closed. Try this, remove the back panel behind the control panel. Make sure the breaker is off to the range. Unplug the keypad ribbon cable to the main board. Power the unit back up. You should get an error code. Now if the broiler still comes on you know you have a welded broiler relay on the board. If the broiler doesn't come on..it's the keypad. Catriver.
Posted on Sep 20, 2007
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
Broiler doesn't turn on completely
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
Dec 17, 2009 | Viking 27" Professional Select Built-in...
Broiler element stays on. I had to trip the
a wire in the back of your stove is grounded... open rear panel after unplugging and look for burnt wires going to the element. the wires will be a higher grade than most..
most likely there is no problem with the broil element itself, but the problem could possibly be located in the oven switch (if it is not digital)
Oct 09, 2009 | Whirlpool Kitchen Ranges
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
Broiler won't turn off even after unplugging and plugging back in.
Check to make sure your broil element is not grounding out causing the element to always stay on when power is applied.
You would need to turn off your house breaker to your oven and check for continuity with an ohm meter between each of your 2 broil element terminals and ground.
Apr 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Apr 08, 2009 | Kenmore Kitchen Ranges
Oven won't turn off
I have a Kenmore model 665.95802 . When I turn the oven dial off , the broiler stays on and on the display you see the code F3 E2
Mar 02, 2009 | Kenmore Ovens
Oven will not shut off broiler element stays on
The control knob more than likely operates a relay that has gotten stuck in the energized position. If this isn't the case then the Temp sensor or thermostat probably shorted internally. Unplug the unit before attempting any work.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Open Questions:
Inner part of Triple element on 790.9912940 won't turn on I just experienced the same problem I've been reading about here and on other appliance repair sites: the inner element of my Kenmore Elite's front-right triple element will not turn on, despite the control panel saying it's "on." The range is about 2 years old, just like many other people have said. Also, Sears naturally wants to charge $65 to even come look at the part, and then several hundred more for a new element. From reading other comments and after talking to Sears, it seems like there is no extra warranty or recall on this part. This triple element is apparently a defective design if I can find so many reports of this exact same issue with only a cursory Google search. Would not have bought Kenmore anyway if it hadn't come with the house, because I've heard of this kind of thing with them far too often, despite their obvious good looks and nifty features... I'd rather not have to spend hundreds of dollars just to keep my $1.2k range working properly - for that price it should have a 5-year warranty at least in my opinion. I'm going to see about removing the element and putting in a new one on my own, as getting the part itself (Sears Direct Part Number 316216702) is only about double the cost of getting a technician to come out in the first place. You can see a handy part diagram of the range top at this link, by the way: http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0610001-00003.png The element that has failed on my range is part 15B in the diagram.
Sep 08, 2009 | Kenmore 92002 / 92004 Kitchen Range
Kenmore 92002 / 92004 Kitchen Range Logo
1,158 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
