FixYa.com
Tags:
Lexmark X3350 All-In-One InkJet Printer
Lexmark X3350 Printer (by 3 users)
posted by GullyF on Sep 19, 2007
Lexmark X3350 all-in-one printer will not print or copy. Error message says there's a paper jam, even when there's no paper in the printer. Tried rebooting printer, computer; and disconnecting printer. Still says to clear paper jam and press arrow key. Pressing arrow key does nothing. It will still scan - but not print nor copy, nothing that involves a piece of paper.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by shawneeblack, posted on Feb 09, 2008
I havve the same exact problem. The printer says no paper or clear paper jam. i have tries adjusting the paper, no luck! I am going to try and reset the printer memory if i can find the instructions. Will let al know if it works for me.
Comment by rslater, posted on Nov 13, 2007
I have tried to obtain a download for the lexmark x3350 all in one but cannot understand the accents. can you help
Best Solution
posted on Dec 22, 2007
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i think i found a solution for this.
its happen when you insert the papers to deep in the paper
jam jusy try to pull out the papers.
if its print its great , if not it should say load paper so in that
moment push the papers a little deeper.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 23, 2008
Thanks for Trying (70)
Guest
Guest
Rating: 0%, 0 votes
This happened to me and after trying many things, I finally looked inside with a flashlight and found there was a small corner of paper stuck inside.It must have ripped off of a page I had printed earlier.After I got it out of there, everything was ok.
Solution #3
Not Rated (0)
shawneeblack
Rating: 0%, 0 votes
Thanks for everyones help, what worked for me is to reinstall the software that came with the printer. Works just fine now.
Solution #4
posted on Sep 28, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Re-install the printer.
Can you Help with these Printers problems?
about to give up
i have a color caritage error... Answer This...
lexmark x3350
i have cleaned my scanner, and... Answer This...
lexmark printer
i cannot reinstall my printer... Answer This...
error 1203
help me connect printer to...
My friend just gave me a used... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
