Question about GE JBP69 Electric Kitchen Range
Burners come on in the left front with the switch turned off
My spectra range just shut off and then the front left burner was turned on. It smelled like something had burned and that is why it was malfunctioning. The front left burner stayed on and is still on even though the knob is off. I think I need to change the switch control in the back but not sure. Also there is three different types depending on watts and I don't have my owners manual. Any suggestions?
  • GE Master
  • 3,498 Answers
UNPLUG THIS UNIT IMMEDIATELY!! Find a GOOD appliance repair store and take your make/model/serial numbet..etc..etc,, with you.. they will be able to get you what youneed...
Posted on Aug 02, 2017
catriver
  • 878 Answers
SOURCE: GE Spectra XL 44 Self Cleaning
Ray, sometimes the burners get gunked up. Remove the cap and burner and see if the small orifice that is located by the spark electrode is clogged. Clean it out with a paper clip. Make sure the burner cap has good contact with the burner. Catriver..post back.
Posted on Dec 08, 2006
SOURCE: GE Spectra Oven not working
What is "the board"? and is this replaceable by a fairly competent user or does this require a service call? Thanks!
Posted on Feb 07, 2007
jsrock516
  • 5911 Answers
SOURCE: GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Posted on Aug 13, 2007
reg501
  • 413 Answers
SOURCE: GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Posted on Jun 05, 2008
MNTECH
  • 1543 Answers
SOURCE: natural gas orifice burners
Before you get too involved, check to see if the natural gas orifices are still with the range. Usually, when the conversion is done, the person who converts the range puts the original natural gas orifices into the holder which contained the LP ones, then replaces it. Look for an inch and a half long metal strip holding the four brass orifices held on by one screw very near the range gas regulator. (the regulator is the part the gas line connects to on the range) Also, look for the conversion instructions in the original installation and set up instructions, or attached to a sheet of paper on the back of the range. You will need to change the plunger in the regulator (Unscrew the cap, flip the plunger around, and replace) and turn the orifice spud on the bake and broiler burners three full turns counter-clockwise also. (using a 1/2 inch open end wrench, counting twelve 1/4 turns) Orifices will require a 7mm or 9/32 inch nut driver or socket to change. The orifices are different for the simmer, regular, and high output burners. (have a "I", "II" and "III" marked on them to help identify them, respectively.) The left two burners are both "regular output" burners, and use the same orifices.
Posted on Apr 20, 2009
Burners will not light
Hello bdrillbit - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Feb 12, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a GE Spectra XL44. I can not light the front two burners. I can see a spark coming from the burners and I can smell the gas however no flame. The rear burners work with not problem and the oven...
The range or cooktop ignitor works in the same way as a car spark plug. High voltage is supplied to the center electrode and it arcs to ground. If the ground, burner cap, has grease or grit on it then it will inhibit the spark and cause the symptoms you are seeing. Pull the cap off, inspect the ignitors for any cracks. If no cracks, look to where the arc is going to - the exact location. Clean thoroughly with scotchbrite pad. If this doesn't fix the problem, you may have to call tech to replace ignitors. Cleaning fixes most of these problems. Hope this helps,
Aug 15, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Have a GE Spectra Elactric 4burner w/Self
the two front burners are not working - no electricity
Mar 14, 2010 | GE Spectra JBP78 Electric Kitchen Range
Igniter clicks on the wrong burner
The spark supposes to go to all burners. The spark igniter of the non working burner needs to be replaced.
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Burners not lighting
You have one or more spark switches defective or a loose wire to the switches.
They are located on each gas valve stem.
Yes they should be replaced for safety.
In the interim you can match light the surface burners.
Feb 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
Dec 06, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JBP69 Electric Kitchen Range Logo
49 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
