Question about Margaritaville Frozen Concoction (DM1000) Blender
Plastic pieces on glass jar and base are worn out and shaved down
The female plastic piece on the blender base no longer meets the male plastic teeth on the blender jar. These are both shaved down. Machine works fine but these plastic pieces need to be replaced (appears that they should have been metal or a harder more durable material). Where can I get these replacement parts? Thanks,
Glen
  • 2 more comments
  • gericksonbel Apr 21, 2009
    Because it is an overpriced piece of Chinese junk Sunbeam doesn't stand behind!
  • tsweatt Apr 27, 2009
    Plastic rotory parts Female end at bottom of pitcher is worn down, Need to find a replacment part.
  • Anonymous May 04, 2009
    i have the same problem plastic pieces worn down and wont shave ice because no connection please help me with how to fix machine so i can use again
  • Steve Maring
    Steve Maring Apr 08, 2014
    You can buy the part at thegourmetdeportco.com, but the installation instructions don't work. Since i was within the 12 month waranty, Margaritaville sent me a brand new machine.
    Problem Solver:
  • 7 Answers
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Posted on Jan 26, 2010
  • Steve Maring
    I had the same issue, but it was not related to the gasket being installed incorrectly. Go check Amazon reviews; this issue is prevalent. I got the replacement part ($5) from thegourmetdepotco.com, but the installation instructions didn't work. Since I was within my 12 month waranty, Margaritaville sent me a brand new machine (and told me to keep the one I have). Design SHOULD have metal rotors.
    Problem Solver:
  • 5 Answers
Culinary part unlimited. had the same problem. # is 800 543 7549. they had to back order it 2-3weeks $15. better then buying a new jar!!!
Posted on Jul 15, 2009
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Broken plastic base for CBL25
FIXYA does not know who might have a broken JUG .
Dec 03, 2017 | Breville CBL25 Moda Bar Work Top Blender
I need a part for my Black & Decker Model BL2020R.
Perhaps you could find Black & Decker parts web-site for your blender model BL2020R. It will show a parts diagram for your machine. Find the part and order it online.
Dec 24, 2012 | Applica Black & Decker Blender With Glass...
We have a Black & Decker BL9000 blender. On top of the base, there is a plastic disc that meshes with the bottom of the jar and drives the blades. I think one of the kids was making smoothies and...
Available replacement parts can be found here:
http://www.directpartsandproducts.com/blenders-bl9000-c-1_4_60.html
or here:
http://www.abtecparts.com/Black_&_Decker_blenders_BL5000BL6000.htm
I have not seen the drive gear made available. You could try making an inquiry with either of the above sites to see if they can locate a replacement. Alternatively contact a local small appliance repair shop; they may be able to scavenge the part from another blender.
May 16, 2011 | Black & Decker BL9000 Blender
Does the white plastic base bottom of the glass blender come off for cleaning or is it attached permanently
Yes the white plastic base comes off. There are several model of the BL10450; here are the Instructions which contains an illustration of the assembly:
https://www.unitycart.com/pjss/parts/parts_classic.asp
See the notes on Blender Jar Assembly. It turns on clockwise; off would be counter clockwise.
Mar 07, 2011 | Black & Decker BL10450 10 Speed Blender
KSB5600BO kitchenAid blender blades broke and l am looking to replace them but I can't find the right parts. Do I need to just by the whole Jar assembly?
You don't need to replace the entire jar assembly. Have you tried to contact Kitchensid. They make high quality appliances and will probably send you new blades for $0.
Apr 19, 2010 | KitchenAid KSB560 5 Speed Blender
The plastic threaded base for the jar on this blender haier 2 speed / glass jar is cracked - is part available ? thanks
The base ring part probably is available, however, you MIGHT want to try gluing it with the BLACK ABS plumbing glue. It is surprizingly strong if you have clean break
Sep 16, 2009 | Haier HB500 2-Speed Blender
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Power flashes but doesnt start
Yes, I know what it is. On the base of the blender jar (the plastic base) there are some "fingers" that must contact the base to allow operation to take place. Turn it upside down and look at the little plastic "fingers" around the outside periphery of the plastic base.
These fingers tend to break over time... mine only has two left right now, and it only works in one particular position as a result.
Rotate the blender jar one spot at a time until you are able to operate it "normally". I use it for margaritas, and it won't allow me to push the button for Frozen Drink unless the jar is in the right position.
I am going to try and find a replacement base (or entire blender jar) somewhere... or else I will finally have to retire my favorite blender of all time!
Dec 20, 2008 | Oster 6700 Work Top Blender
Margaritaville Frozen Concoction (DM1000) Blender Logo
2,305 people viewed this question
Top Margaritaville Blenders Experts
john h
Tom Chichester
Are you a Margaritaville Blender Expert? Answer questions, earn points and help others
