Question about Panasonic SC-HT830V System
F61 code what do i do?
Hi i have a panasonic 5 disk cd player and i have gotten a F61 code what does that mean?
  • 107 Answers
From Panasonic:
≥Check and correct the speaker cord connections.
If this does not fix the problem, there is a power supply problem. Consult the dealer.
Heres the link....see page 47
http://service.us.panasonic.com/OPERMANPDF/SAHT830V.PDF#page=45
Posted on Apr 19, 2009
5 CD changer, model sa-ak600. What does code f61 indicate?
F61 means that the power amp has something wrong with it.
It could mean the IC501 has failed or that there is something wrong to the power supply to it.
The good news is the service manual is free online. You can get it by simply putting the model number into google and searching for the PDF of it.
Jan 02, 2016 | Panasonic Audio Players & Recorders
Panasonic error f61
If you do not know what an audio output IC is, what would ordering one do for you? And unless you have the know how and special gear there is no freaking way you could ever replace it.
Either have someone repair it for you or go shopping.
Aug 17, 2017 | Audio Players & Recorders
F61 on panasonic SA-AK220
There are no error codes in the users manual. In this series of models panasonic has standardized error code meanings. F61 means a failure in the power out circuits. Your first option is to remove all your speakers and the associated wiring with the power off. Repower unit and see if error is still there. If not, you have a speaker or wiring problem. If still there, you have an internal failure requiring service.
May 19, 2012 | Panasonic Audio Players & Recorders
What does f61 mean?
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 16, 2011 | Panasonic SC-AK18 CD Shelf System
My SA-VK70D got F61 and imediatelly turn off..:(
i have vk70d and i have same problem .....your cooling fan not working ...chand it ...its work ....
Sep 03, 2009 | Panasonic SCAK410 5-Disc CD Changer
I WHAT IS FULT OF F61 IN SA-AK177
HELLO
F61 means a protection code which normally means there is a fault with the audio output IC. Check all your cables for shorts etc, and try hooking it back up. If the error is still there you'll have to put it in for service.
ALL THE BEST!
Sep 01, 2009 | Panasonic Audio Players & Recorders
My panasonic turns on but shows the letter f61 what does that mean?
F61 just means 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic (IC 502).
May also be the fan if it has one make sure it is clean and can spin freely.
Hope this helps. Thanks
Sep 13, 2008 | Panasonic Televison & Video
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Panasonic SC-HT830V System Logo
504 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
