Question about Maytag MFI2568AE Side by Side French Door Refrigerator
Blinking display Ice maker and water stopped working. Display then started blinking and ice door started opening and closing. Unplugged the door connector and ref seems to still work ok. I then pulled the display and unplugged the 3 pin connector and it stopped the blinking, but still no water and ice. Replaced the electronic board and got the same results. Thanks for any help..
  • jph3021 Sep 20, 2007
    I replaced the board on the door, the one with the digital readout displays. Thanks for the help, I will try the high voltage board.
    President:
  • 878 Answers
Jph, this is a classic symptom of the high voltage board failure. What board did you replace? The high voltage board is the one on the back side of the refer, left hand side. Catriver.
Posted on Sep 20, 2007
  • Ron Marek
    Ron Marek Sep 20, 2007
    jph, after installing the high voltage board you will have to enter the code for your refer. The board will come with instructions on how to do this. Your code will be on the model number tag, lower right hand side of the tag. Four digit code. Catriver.
SOURCE:
Kenmore elite refrigerator
Check the door switch by depressing it with your finger. maybe not making contact that well with the door ?
Dec 12, 2013 | Refrigerators
Blinking light in refrigerator
I think that's the light letting you know the door is open so it won't drop ice. When I held in the catch on the left side (as if the door was closed) the red light went off for me.
-Drew
Jun 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Panel flashing, ice door opening and closing constantly
That is a faulty icemaker solenoid switch, or a contact on wiring.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 10, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Dispensor display going haywire/ ice shoot valve opening by itself
It is not the circuit board in the door, it is the one in the rear of frig. I had the same problem, and replaced the front board with no results, replace the HV board and fixed the problem..
Sep 21, 2007 | Maytag MFI2568AE Side by Side French Door...
RS2534WW
I just had the exact same problem with my Samsung RS2534WW Fridge from Best Buy. I think the freezer seal was not totally shut and something inside was pushing against the door, so it couldn't close tightly, but was not open enough to trigger the chime alarm. In the morning, the freezer temperature display was blinking. Later on it settled around 59 degrees. Here's what seemed to work for my particular situation: First I pushed the ice selector button, from cube, to crushed, to No Ice. Then I unplugged the fridge for about 10 to 15 minutes. Next, I plugged it back in and held down the Power Freeze and Power Cool buttons simultaneously until the chime sound is heard. I read this should reset it, but my display turned completely off. So, I held in the Power Freeze and Power Cool buttons again and as soon as the display lit up, I let go. The freezer temperature no longer blinked and settled at 56 degrees. Next, I opened the lower service panel in the back. First, I verified the (evaporator) fan in the middle was running (it was). It seems to pull air in on the freezer side and blow it over the compressor and out the fridge side. The air intake side had a lot of dust, especially on the condenser coils, so I vacuumed it out. Next, I opened the freezer door and noticed a build-up of ice around the freezer air ducts in the back (both exhaust and intake vents). I then used my hair dryer to thaw out the ice and wiped up the water. Next, I closed the freezer door and the temperature read 59 degrees. It stayed on that temperature for 8 hours and then the temperature started to drop quickly and it returned to normal. At that point I turned the ice maker back on and it has been working fine ever since. Apparently, the unit has an 8-hour cool and defrost cycle. I read someone else turned off (unplugged) their fridge overnight with the doors open to let it defrost. When they plugged it back in the next morning, all was working fine. If those tips don't work, you may have a problem with either your cooling system or defrost system, or it could be something as simple as a blown thermal fuse. Hope that helps!
Aug 14, 2007 | Samsung RS2534 Side by Side Refrigerator
Freezer defrost all. RS2556
The most likely is that the door was not closed properly, this is very common on this model, what happens is that the door closes against the freezer contens and therefore appears closed, this allows warm air into the unit which starts to melt the ice, if this should happen again it is a good idea to completely defrost overnight with the doors open and then re start the next morning as ice often builds up behind the rear panel. Regards Advisor
Jul 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Apr 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
309 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
