Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener remote won't work
My Craftsman garage door opener works with the wall console, but not the remote. I found out the wall console was locked somehow, fixed that, but meanwhile I had changed batteries in both remotes. Now, neither remote works, only wall console. Tried to erase all codes, but didn't work. Any suggestions? My garage door opener will not work with the remotes or my car's Homelink system. I've replaced all batteries, cleared all codes, and reprogrammed all remotes and Homelink. The garage door will open once or twice but then ceases to work from remotes. Prior to my troubles the remotes and Homelink worked intermittently.
  • s_hunter830 Apr 20, 2009
    We have a Craftsman 1/2 hp. The wall unit opens/closes the garage door just fine. But the remotes and the wireless keypad will only shut the door one time and then stop working. It is consistent. Open the garage door from the wall unit. Leave through garage. Use keypad or remote control to shut garage door. You cannot open the garage door. Or, if you don't shut it within some period of time, then neither works (keypad or remote). It seems like a temporary code has been set, but we've cleared all codes. We can't get it all back working consistently again.
  • 504 Answers
Look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Posted on May 29, 2010
Remote won't work but keyless entry does on garage door
If the light in the wall control is flashing press and hold the lock button for 3 seconds. Your remote should now work.
Jul 23, 2012 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener remote does not work.I have a craftsman garage door opener manufactured in 1999. The garage door opener remote panel has a green light on and will open the garage door. The remote,...
Make sure the green light in the wall control is not flashing. That locks out the remote. If it is press and hold for 3 seconds the lock button on the wall control. It could just be that your remote has failed.
Dec 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
meerkat1 your receiver has quit working which is part of the logic board. The logic board runs around $80.00 for the part alone. Might be time to get a new opener.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
692 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
