Monitor on HP Pavillion a656x---blew up the power supply--had an extra and installed it--when machine was turned back on--monitor displays "VIDEO CABLE CONNECTED?---what am I going to do----help!!!---
Monitor on HP Pavillion a656x---blew up the power supply--had an extra and installed it--when machine was turned back on--monitor displays "VIDEO CABLE CONNECTED?---what am I going to do----help!!!----ideas??
    Scholar:
  • 97 Answers
First thing I would do is try the monitor on another system to see if it's in the monitor or computer. Next would be to fire it up and see if you hear a beep from the motherboard. Most consumer pc's will come with a small speaker that sounds on startup. If you don't hear this beep it could be indicitave of a fried motherboard.
But it sounds to me like your video card or onboard video was messed up when the power supply conked out. If it's onboard video you may be able to switch to a video card. If it's a video card you may need to replace it.
Also check to make sure there are no loose wires, that your video card is seated firmly, and that your connectors are all snug. If none of this works then you're most likely looking at a motherboard replacement.
Posted on Jul 30, 2009
HP Pavillion a1514n Won't Turn On
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
I have an HP Pavillion dv9000. I RARELY use it, but my screen is blank. The power and lcd lights come on, but the screen is blank. I've taken the battery out, connected the power cord and turned the...
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Test with an external monitor attached to the laptop. If you get display on the external monitor, then this confirms the case.
Aug 21, 2010 | HP Pavilion dv9000z Notebook
HP Pavillion f1903 monitor, power light turns blue, no display
sounds like the flourescent backlights are burnt-out--very expensive to replace and dangerous
Mar 14, 2010 | Computers & Internet
My monitor does not work
Turn the screen of the laptop to catch some light from the window or a lamp
Can you see the Window screen very faintly in the background, if you can the backlight or the inverter has gone
If yoyu cant it is screen itself
Feb 18, 2010 | HP Pavilion dv9000z Notebook
No video out to monitor from desktop.
sure not hard at all. if the monitor is connected to the default onboard video adapter, this is usually one of the first things to malfunction on a new computer. if the monitor works when connected to another machine, but when connected to the desktop the monitors amber or orange light comes on but no video, this usually means there is a connection problem. usually most modern monitors will display a "no input" or "no video" message meaning the connection to the computer is bad. try getting a new video adapter (usually pci/pcie video card) and installing into the pci/pcie video slot in the back of the computer. most are plug and play and require little to no configuration. you should be able to find a nice one for about $20 - $30 dollars at www.tigerdirect.com . hope this helps. please rate me and thanks for choosing enterprise computing solutions.
Oct 07, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
I have a hp pavillion dv4 1225 dx , my display is really bad , like almost gone, i would like to back up my documents before shipping laptop to hp for repairs, so i was thinking of connecting an external...
You can connect any HDMI or VGA (15 pin) compatible monitor or TV, almost every monitor has VGA connector or VGA adapter at the end of connector and you can use it.
Sep 28, 2009 | HP NB199UA Pavilion Notebook
HP Pavillion won't turn on.
Hmm, did the CA damage any part of it? Sounds silly I know.
And is the power in the, Optical Disk Drive, HDD, Graphics Card and of course on the Motherboard?
Keep it on for about 40 minutes monitoring the heat ever so often even though there is nothing on the Monitor.
By the 40 Minutes it should be mid temp - Hot.
Best of Luck. Tom.
Jul 13, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
My HP Pavillion laptop turns on but the screen doesn't show.
You could be expierencing a problem with your monitor screen. try this.... connect another monitor screen to the VGA port of your laptop. Now try booting up. Look for and push Fn + the key that turns on a secondary display. if the monitor screen comes on. you need
another laptop monitor. At least you can use your laptop with the second monitor for now.
Jun 16, 2009 | HP Pavilion dv9000z Notebook
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
