Question about GE Optical Mini Mouse ho98094
GE wireless optical mini mouse
Just bought this, having difficulty with the mouse sometimes not responding, or tracking well.
  • 1 more comment
  • melanie5 Sep 19, 2007
    Thanks I'll try your suggestions!
  • julie arnold Jan 04, 2008
    i have this exact same ge wireless optical mini mouse and have experienced the same problem, it will just stop responding? i am starting to believe it is a manufactures defect of some kind? i will remove the batteries and then put them back in and this will sometimes work.
  • Carl Light Sep 22, 2008
    I have the same problem, removing both of the batteries and them putting them back in worked for me as well, for the meantime that is .  I had only used it for a couple hours when it stopped working.  I tried the "pairing up" of the two pieces with the little buttons, no luck.  Only the battery trick worked for me.  I hope this is not a frequent problem.
I also have a mouse pad with a wrist rest, and i had it before i purchased my mouse, so i know it does not correct the problem
Posted on Jan 04, 2008
  • 3 Answers
Not sure if it could be a mouse issue or a surface issue. Some things to keep in mind: 1. Most mice have a "channel" buttof on the bottom used to pair it with the wireless base. Try pressing this a few times to see if you get the desired effect. 2. Surface has a lot to do with quality of the mouse tracking beacon. I suggest dropping $10 on a mousepad. I have a mouse pad with a wrist rest I paid $15 bucks for and even though the mouse doesn't move as fast as on the desk, simple changes in the Control Panel for mouse tracking solved this issue. 3. I am not one to harp on a particular mouse manufacturer but I have had a great deal of good experiences with Logitechs line of mice and keyboards. Hope this helps. D.
Posted on Sep 19, 2007
SOURCE:
Do I need a receiver plug-in for my Gateway laptop to use a GE wireless optical mouse model 98763?
Garrett, Yes, plug in the receiver that came with mouse. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE Wireless Mouse and Driver Problem Fix
http://techin.oureverydaylife.com/ge-wireless-optical-mini-mouse-stepbystep-setup-13706.html
GE 98796 Wireless Optical Mouse Manual
Aug 22, 2016 | Gateway Computers & Internet
Optical wireless mini mouse 98763 feature #9 is
I had all the same problems listed in fixit and found that all it took was placing all NEW batteries in the mouse.
Press the blue light button on the USB and the little black reset button on the bottom of the mouse at the same time. Worked good from there on.
Feb 23, 2010 | GE Wireless Optical Mouse
How do I change the AAA batteries in my GE Wireless Optical Mini Mouse
Grip the sides of the mouse with both hands and slide the battery cover
back with both thumbs. Then, replace the old batteries with two AAA batteries. Replace the battery cover. Hope that helps.
Jul 30, 2009 | GE Wireless Optical Mini Mouse 3087897985
Mini mouse GE 98763 stop working and I can't start
If you are using window you can download the software at:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Choose system and select wireless optical mouse
Jul 30, 2009 | GE Optical Mini Wireless Mouse 98793
MY GE WIRELESS OPTICAL MINI MOUSE POINTER MOVES ON ITS OWN
I get the same thing from a optical with cord.
Change the pointer speed. Look in Start > Control Panel > Mouse > Pointer Options.
Nov 24, 2008 | GE Wireless Optical Mini Mouse 3087897985
GE Wireless mouse & keyboard
are both keyboard and mouse communicating with a single wireless devices, or each has it's own? sometime you need to sync the signal to the wireless device. but do this first... ask your sister if the mouse was working before she gave it to you, there is a possibility that the mouse is broken/no working. if it's an optical mouse, the mouse that has lights sensor, make sure it lights up...
Feb 16, 2008 | GE Wireless Optical Mini Mouse 3087897985
GE Optical Mini Mouse ho98094 Logo
229 people viewed this question
Top GE Computers & Internet Experts
Damen Wong
Damen Wong
Ekse
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
