Question about HP Compaq Evo Notebook N410c
Battery My laptop can only be used while plugged in, not very easy to be mobile. How would I replace the battery with a new one?
  • 150 Answers
The below was copyed from an earlier post of mine, it applies to you. It's one of two things, the more likely of the two is that that battery is totaly shot, laptop battery's are usually only good for 1.5 years then loose there ability to retain a charge. It sounds like that one's just done. Unfortunatly that those batterys cost more than there worth, 100 bucks or more. The second possibility is the power cord, is that the original power cord for that? Or was on that was bought aftermaket, some aftermarket chargers will only power your laptop and not charge. Also remove the battery and check for corrison. You can build your own battery fot a a laptop if got a few hours time, and are good with a soldering gun. You get the litium ion cells you need for about 40 bucks. Good Luck Follow the below link for a step by step on how to build your own battery http://www.metacafe.com/watch/479447/lap...
Posted on Sep 20, 2007
Battery for averatec 300t
Most laptops are the same as far as changing out the Battery. On bottom of Laptop,at back of Laptop you will see long skinny Plate for Battery. Take out screws,or some just snap out. Battery will have plug on right or left side, unplug,install new Battery,put plate cover back on. Good to go. Good Luck, easy task....
May 17, 2014 | Averatec Computers & Internet
My nokia 5130c-2 starts charging automatically when i put in the battery without connecting the charger, then the battery discharges in a few hours..... pls help me.
There might be some battery issue you need to replace this battery to another one and please don't left your mobile while you are charging battery cells going to dead if its over charge and you will going to lose your battery and mobile as well Laptop Rental Laptop Hire in UK Wales Ireland and Scotland Hire Laptops
Oct 23, 2017 | Nokia 5130 Cellular Phone
My battery on my JVC Mobile Mini Note PC/MP-XV841 has not been charging when I plug into an electrical outlet.
How long have you had the battery?
The average life of a battery if charged everytime the laptop is used can be as low as 12 months.
Try a replacement battery if this one is exhausted.
Jan 25, 2011 | JVC Mobile Mini Note PC MP-XP3210 PC...
My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
Is there an easy way of telling whether the battery is dead?
Hi
Thank you for your qiery
This is occuring as windows is only reporting battery life with charger plugged in
If the laptop dies after taking the power lead out then im afraid the battery is pretty mych dead and will need to be replaced
Spare used batteries can be purchased of ebay readily
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | ASUS P5V800-MX Motherboard
Lose all battery power within minutes when not plugged in
Laptop batteries typically need to be replaced every couple of years or so.
Much like cellphones, if you overcharge them then you can ultimately kill cells and keep if from holding any juice.
Good way to keep this from happening in the future is by simply monitoring the amount of charge your battery has while its docked at an outlet.
IF it has a full charge simply take it out and use it on ac power and reserve the battery life for when you need to be mobile.
A new battery can be found either on ebay or directly through the manufacturer. Steer clear from off-brand replacements as I have typically seen a high failure rate.
Hope this helps.
Dec 11, 2009 | Acer Extensa EX4420-5239 Notebook
When should you change out your laptop battery?
Laptop batteries life will vary depending on use. In my experience it is suggested to replace the battery within 3 years. This depends on your requiring the battery.
If you wish to work mobile then a new battery makes your investment a tool, and should be considered.
Apr 14, 2009 | HP Pavilion dv1000 Notebook
New battery needed!
The Everex SA2052T uses the same battery as a Averatec 2260 (2200 series) laptop. I purchase one from provantage.com this week. The battery is made by BTI and the model number is AV2200. It works perfectly.
Nov 17, 2008 | Everex StepNote SA2050T Notebook
Laptop battery working
Battery led is blinking, this usually means your battery is faulty. Try replacing the battery with a new or tested second hand one.
Hope this helps
cheers
Feb 14, 2008 | HP Pavilion dv9000z Notebook
HP Compaq Evo Notebook N410c Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
