Question about Acer TravelMate 252LMi Notebook
Will not power up
On pushing the power up button the fans starts and the hard drive appears to start be it then bleeps four times and shuts off? Is it a faulty hard drive?
  • 3 Answers
Depending on the manufacturer of motherboard, usually 4 beeps indicates a memory error. To check, do the following. Warning: try to do this in an area free of static electricity. 1. Your user manual should show you where the panel is to access the memory. You will beed a small screwdriver (or sharp tip of an old steak-knife) to get the screws off. 2. Most memory errors are caused by memory that needs to be "reseated". You will see the memory looks like it is lying flat on the mother board. There are two clips on the side that should be pushed back to allow the memory to "pop" off the rail. 3. Gently, but firmly push the memory back down into place. It should quietly snap back into place. 4. reassemble panel. If this does not fix the issue, there is a more serious motherboard issue. You will need to call the Manufacturer (Acer) to determine if the system is under warranty for replacement parts. Hope this helps. d.
Posted on Sep 19, 2007
My freezer keeps going into intermittent thawing were the fan shuts off. I have checked the four thermisters and it appears that I am not getting a constant reading, but it does fluctuate near the 16
ge fridgs are hard to check.. but I have seen the main pcb cause exactly what is going on with your unit... if this unit has some age on it the pcb would be a good place to start.... does the evap fan run when u push in the fan door switch?? if not replace the evap fan motor at the same time.. it will save you a lot of headaches...... hope this helped....... ken
Oct 09, 2014 | GE Refrigerators
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
PS3 won't boot up. It starts but will not load menu from the hard drive.
try rebooting hold down power button until it bleep twice and should turn off hold it down again unit it bleeps 3 time then u have secret reboot menu 4 ps3
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
My ps3 will not turn on... when I start up by pushing the power button I can hear the fan turning on, it boots on, and then turns off a few seconds later. any advise would be greatly appreciated.
hello, try resetting it, turn on the ps2 press and hold the standby on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleeps release the button it should reset
regards
shaun
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
Emachine wont start
remove all external and internal peripherls.
example for external: mouse, monitor, keyboard, printer.
Internal: hard drive, memory modules, video cards, modem (if there's any), optical drive or dvd drives.
just leave the motherboard, power supply and processor intact, try turning on the computer with out those components mentioned. see if you get a beep sound before it turns off, but if not the most logical part that needs to be replaced on this type of problem is the power supply if that doesn't work the next thing to do is replace the motherboard. hope that helps
hit me back on the results. thanks!
May 25, 2009 | eMachines T6211 PC Desktop
Computer won't wake up
ok, there could have been a graphics issue in the bios caused by the windows graphics drivers, heres what you could try........... remove the power cord from the back of the machine, remove the side panel to allow access to the motherboard, you will see a battery! take it out for 10 mins and push the on/off button a couple of times, this will drain any remaing power from the motherboard, after 10 mins the CMOS should have cleared so you can replace the battery, plug in the power and turn the machine on hopefully you'll get a signal
good luck
Nov 17, 2008 | Computers & Internet
Boot Problem in TASCAM 2488
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
Jun 19, 2008 | Tascam 2488 Portastudio Multitrack...
My Presario SR1750NX won't boot up
hold the power button for 10 seconds it turn off ur cpu and then start the cpu and hold F5 key u get windows boot menu select safemode try to login after login check in the controlpannel poweroptions chek in advance option see the menu down wheather it is in standby then change it to shutdown and apply the setting. and check it out it may work r else please try to repair the os.
Feb 10, 2008 | HP Compaq Presario Media Center SR1750NX...
Computer powers off during boot
Hmmm...try resetting CMOS & checking all external peripheral connections: (KB/mouse, monitor, etc.)
Oct 26, 2007 | ASUS A8N-E Motherboard
Acer TravelMate 252LMi Notebook Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
