Document sometimes doesn't print
I have a Lexmark 5600 printer. When I give a printing instruction, sometimes the document prints after a while. Most of the times, the document does not print at all. What can be the problem? This is a new computer and a new printer. I had the same problem with my Samsung CLP-300 printer, which I then changed to the Lexmark.
  • 744 Answers
If the documents are large or have a lot of pictures and pages, printing can take a while. However, if the same thing occurs with a one page letter, try re-loading the printer driver(s) and/or check the printer settings, especially those that have to do with spooling. It's usually best to choose the setting that allows the document to spool so it prints faster.
Just in case you don't have the manul, here is a link to the book in PDF format:
http://www.lexmark.com/publications/pdfs/2007/5600-6600/v7677571_en.pdf
Posted on Apr 19, 2009
Lexmark wireless printer 1400 series prints blank pages
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 22, 2012 | Lexmark Z1420 Printer
Lexmark x5470 not printing on all the page, some text are missing
What is the operating system installed on your computer? It could be a printer driver issue or could be due to clogged cartridge nozzles. Try the steps below to fix the problem:
  2. Go to Programs.
  3. Go to Lexmark 5400 Series folder.
If that doesn't help, please visit the Lexmark website to update your Lexmark X5470 printer driver. Select your operating sytem > click on FILTER > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation. Then try to print again to verify that the problem is fixed.
Jan 17, 2012 | Lexmark X5470 All-In-One InkJet Printer
My Lexmark x4850 has stopped prin?t the computer. What is wrongting . Sometimes it will print when I restar
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lY7NTO. Select your operating system, download and execute the file. After the install process, try to print a document again to verify that the problem is fixed.
Oct 23, 2011 | Lexmark Wireless X4850 All-In-One Inkjet...
Ran out of ink, changed the ink and the printer prints a blank paper...checked the ink everything is good...still nothing printing??
Make sure you are inserting genuine Lexmark cartridges.
Try to re-seat the cartridges into the printer. Remove the cartridges > close the printer cover > unplug / re-plug the printer into the power source to reset it > when the printer turns on, firmly reinsert the cartridges. Try to print a document again to verify that the problem is fixed.
If that doesn't help, try to clean the print cartridge nozzles. Open the Lexmark Solution Center on your computer by going to Start menu > Programs / All Programs > Lexmark Z600 Series > Maintenance tab > Under Select a Maintenace tool, select Clean to fix horizontal streaks. > click Print. Then try to print a document again.
Sep 13, 2011 | Lexmark Z615 InkJet Printer
How do I correct this printing problem? My colored letters on the page print. Black print doesn't print onto the paper. I have a lexmark z615 printer.
Try to clean the print cartridge nozzles. On your computer, open the Lexmark Solution Center by going to the Start menu > Programs / All Programs > Lexmark Z600 Series > click the Maintenance tab > under Select Maintenance tool, select Clean to fix horizontal streaks > click Print. The printer will then print a test page forcing ink through the cartridge nozzles and clean them.
If that doesn't help, remove the black cartridge and try to manually wipe the cartridge nozzles with a slightly moistened soft cloth to clean it from dirt and clogs. After wiping the nozzles, reinsert the cartridge into the printer. Print a document again to verify that the problem is fixed.
If the problem continues, try to insert a different known working black cartridge to identify if it's a faulty cartridge issue.
If you still need assistance, please contact Lexmark Technical Support Center.
Sep 12, 2011 | Lexmark Z615 InkJet Printer
Lexmark will not printer it is 5600
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 03, 2011 | Lexmark C533DN InkJet Printer
When I go to print a document, it pulls the paper through, but does not print
Try to clean the printhead nozzles on your Lexmark Impact S305 printer. From the printer operator panel, press Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a page forcing ink through the printhead nozzles and clean them.
If that doesn't help, please visit the Lexmark support page to determine if your printer is affected with the printhead issue. Also, make sure your printer is updated. The firmware update will help give you a highly reliable print system.
Click here to validate your serial number and/or update your firmware.
Sep 01, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Lexmark 5600-6600 series delete print job
when you want to delete some print jobs command try to unplug data cable first then cancel print jobs this will sure help your query
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 25, 2010 | Lexmark X5150 All-In-One InkJet Printer
New Hp Officejet 5610 All-in-one - Printing?
You may have a couple of problems. First, you say you have more than one icon in your Printers dialog box for 5600 series printers. My guess is that you installed two different drivers, one for the 5600 and one for the 5610.
Try deleting the 5600 printer icon and making the 5610 the default printer. Run the test print again to verify it works, then open a Word document and see if you can print that.
This brings me to the second issue; what exactly are you trying to print? The issue in this case, may not be the printer but an issue with the document. Some documents have a security feature that prevents printing. Try different documents (Word, Excel, etc...) and see if the problem is across the board. Post the results here.
Thanks.
Sep 23, 2008 | HP Officejet 5610 All-In-One InkJet...
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
