SOURCE: Chevrolet 2500 Not Running, May Be Fuel Filter Sensor
if it dont have good compression it will not start check the comp and make sure there no water in oil if fuel pressure is low it will not pop the injector open try some starting fluid
SOURCE: 2001, Duramax Deisel 6.6 won't "restart"
fuel pump is obviouslynot working !
check it & its wiring!!!!!
SOURCE: 2007 chevy silverado 2500 hd duramax shut down
mo me it sounds like low fuel volume i would check my lift pump
SOURCE: Fuel gage shows ''E'' and ''low fuel'' on 2002 Silverado 2500HD Duram
Sounds like the sending unit in the main tank is faulty.
SOURCE: 2005 silverado lt 6.6 duramax diesel turbo..engine
Before we do anything else lets do a fuel pressure check to make sure the pump is a-ok as well as the fuel pressure regulator. Your gonna need shop manual for this as well as a fuel pressure tester. If all checks out then move to the Turbo code.
Turbo code looks like the waste gate is stuck open and your not building the boost. Do a visual inspection look for any signs of overheating and bearing wear. Check or change oil as needed.
With regards to the Mass air flow I believe you have to replace it. Keep in mind this thing might be the root of you whole problem.
I strongly suggest you use the shop manual for the codes you got. it will make this repair a snap.
