Question about Technics SA-DX940
Hi, my technics SA-DX 940 all of a sudden started saying overload when I turn it on then says to shut off. It was running fine then one day the breaker in our house popped off. The system was not running at the time. Any ideas. Thanks.
  • hademarre Apr 19, 2009
    Would this go out all of a sudden? And is this the only fix? Any other solutions I can try?
  • 10,594 Answers
Receiver goes to protect mode and shut down when it gets problem in amplifier output section and that happens usually in front left or right channels.
Unplug receiver from AC power outlet for couple of minutes and replug back in and turn power up. Still no joy, then out put section is damaged and you need to replace defective output chip.
You can download Service Manual of SA-DX940 from Manual Zone for small fee if you wish to repair it yourself. Required parts can be obtained Part-Store.
Hit "add a comment" button for further query / info.
Thanks.
Posted on Apr 19, 2009
  • Shahid Electronics
    Shahid Electronics Apr 19, 2009
    As you know it is 5.1 channel receiver that means it has 5 amplifier sections and any of 5 got problem, protection circuit generate error signal and system control chip shut down receiver immediately to avoid further damage.
    Yes, electronic semiconductor parts can be damaged on voltage fluctuation as receiver already had power failure in house.
    I gave you one suggestion to unplug and replug unit in AC outlet, this will reset amplifier protection circuit if it has any false error signal.
    Thanks.
Why am i getting an overload message when i don't have anything connected to it ?technics sa-dx 1040
double check there isn't a piece of wire that has broken off the speaker cables and is shorting two of the speaker terminals together. The unit needs to be turned off and unplugged for a minute to reset the protection circuitry. If this doesn't fix it, there's likely an internal failure.
Dec 22, 2014 | Technics SA-DX1040 Receiver
SA-DX 1050 overload
The old gal might be leting you no its time is comeing to quit, TO put it mindly, They only last so long, For the cost of repair nowadays to replace output transisters , YOU CAN BUY A PRETTY DECENT NEW UNIT,
Nov 28, 2012 | Technics SA-DX1050 Receiver
System overload (technics sa dx-850)
audio amplifier IC damaged need to be replaced
Sep 25, 2010 | Technics SA-DX850 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Nov 16, 2008 | Technics SA-EX110 Receiver
"OVERLOAD" message-Technics SA-AX730
You can't do it yourself only a good technician or repair center.I don't know the fix it cost.
Jul 07, 2008 | Technics SA-AX730 Receiver
Technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Nov 30, 2007 | Technics SA-EX300 Receiver
first of all, check all the capacitors. Other than that, it needs a repair guy to have a poke about inside it with a screwdriver. Has anything happened to it lately that could have upset it a little bit? such as a powercut or had anything done to the plug? (e.g. change of fuse, and put in one that was a different rating) And is it plugged into a surge protection socket, or a plain old fashioned electrical socket?
Nov 22, 2005 | Technics SA-AX710
Technics SA-DX940 Logo
273 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
