Question about D-Link DI 514 Wireless Router (DI-514)
I have lost the @ on my Dell computer. I can copy and paste it but the @-button doesn't echo anything. How can I get i back? /Ingela
    Novelist:
  • 153 Answers
The problem is not that your Dell lost the @, it is that your keyboard is not sending the data that represents that character to your computer. You need a new keyboard.
Posted on Apr 22, 2009
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
Advice for when my coputer screen freezes and the esc button doesn't help
Hi Donna,
if everyting is frozen and you cannot do anything with your computer, you can wait a couple minutes to see if it is only working on something in the background that is taking up all its resources... if it does not start responding by itself, and you do not want to wait anymore... push the PC's start button that you use to turn your computer on (not the windows start button) for 8 seconds and it should turn off. NOTE: any changes to data that was open and and not saved will be lost.
Hope that helps
Jan 02, 2013 | Dell Computers & Internet
Everything is wiped out and there's absolutely no files or pictures or music or anything. I really want them all back! Please help me step by step with my computer! It's known to be XPS 410 PC...
How did the computer get this way?
You'll have to gauge how important the data you've lost is to you, as it's fairly expensive to have a drive recovered through a data recovery service.
drive recovery services Google Search
There is software that may recover some or all of your lost files, but you would want to install and use the software from another computer to read the drive that you're trying to recover data from.
drive recovery software Google Search
May 19, 2017 | Dell XPS 410 PC Desktop
I cannot copy or paste anything. It displays error called file integrity violated. What should i do to solve this problem. please help me at the earliest.
There is no need to scan the computer. You just uninstall the copying software like teracopy and reinstall it. It works.
------------------------------------------------------ Kshitij Arade
May 08, 2011 | Computers & Internet
How do I cut and paste my resume on a job application on a Dell computer?
You cannot copy and paste it right onto the application (it will garble up). Usually employers have a link on their website that allows you to upload it to them. Also if you are emailing the application, you can send your resume as an attachment with it.
Nov 12, 2010 | Dell Inspiron 8100 Notebook
My ZTE cdma1X modem is not working on windows 7.
Apparently, one of the Windows updates is causing corruption of the Access Control List (ACL's) in the registry. I had entire sections of my registry nodes that lost the ACL'S.
While I was researching the problem, I came across a website where someone had a similar problem with getting windows OS programs/services to run and they discovered that there was some registry corruption and missing ACL's.
There are two different options that I ended up doing to get the system back in operation.
It seems that running one or the other alone will not fix the problem, but doing both should get you back in service.
  1. Make a backup of your registry (and a complete backup of the system wouldn't hurt either!)
  2. Go to Microsoft's website and download a program called subinacl.exe from this site; http://www.microsoft.com/downloads/details.aspx?FamilyID=e8ba3e56-d8fe-4a91-93cf-ed6985e3927b&displaylang=en
  3. Install the subinacl.exe (it downloads as an MSI file).
  4. Copy the code below into a text file and then name the text file reset.cmd.
  5. I copied the command file to my temp folder to run, but as you can see from the cmd file, it contains the path to the executable subinacl.exe.
@echo off
title Resetting ACLs...
cd /d "%ProgramFiles%\Windows Resource Kits\Tools"
echo.
echo Resetting ACLs...
echo (this may take several minutes to complete)
echo.
echo ==========================================================================
echo.
echo.
subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f /grant=system=f
echo.
echo.
subinacl /subkeyreg HKEY_CURRENT_USER /grant=administrators=f /grant=system=f
echo.
echo.
subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=administrators=f /grant=system=f
echo.
echo.
echo System Drive...
subinacl /subdirectories %SystemDrive% /grant=administrators=f /grant=system=f
echo.
echo.
echo Windows Directory...
subinacl /subdirectories %windir%\*.* /grant=administrators=f /grant=system=f
echo.
echo.
echo.
echo FINISHED.
echo.
echo Press any key to exit . . .
pause >NUL
3. As this command file runs it will show you the status of the reset and create a log that you can go back into and inspect for problems.
4. When this command file completes, you then need to open a command window (using Run As Administrator) and run the following command;
secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose >c:\temp\secedit_output.txt (the redirect of output echos the programs output to a text file, but secedit also creates a log file. The program will show you the location of the log file when it is done).
These two actions combined will reset the permissions on the registry nodes back to their default settings.
Reboot and check your Event Log service... at this point it should be running.
After effects of this process which happened to me, were that the Network List Service would not run... I still had network and internet access, however the Network icon in the task notification area had a Red X, and mouse over displayed a tooltip that said "Server Execution Failed". This was a result of resetting the ACL's.
The Network List Service (netprofm) would not run because it did not have permission to run.
In order to correct this issue, you must open the Component Services snap-in and drill down under Computers/My Computer/DCOM Config/netprofm (this is for Vista!) and right click the node, and select Properties.
Click on the Security tab and make certain the correct user names are listed and that they have the appropriate permissions. I have 4 users listed with the same permissions; (your mileage may vary )
  1. Administrators - Perms; Local Launch, Local activation
  2. Interactive
  3. Local Service
  4. System
Next, go to the Identity tab and ensure that The System account (services only) is the item that is checked. Make sure the changes you make get applied.
Restart your computer so the ACL's are refreshed.
Once you come back up from the reboot, things should be pretty much back to normal.
You may find a stray program here and there that may need to have it's permissions reset, but you should be operational.
Mar 19, 2010 | Microsoft Windows Vista Ultimate Edition
I want to restore my Dell inspiron 531 back to factory,
u can try to look in the controll panel to see if there is a restore button in there insted of using a cd
Nov 05, 2009 | Dell Inspiron 531s Desktop Computer
Lost dell remote access iconon taskbar
If you still have the shortcut for Dell Remote access in your start menu, right click on it and select copy, then right click on your taskbar and click "Open Folder" when the folder opens click paste.
Mar 18, 2009 | Dell Computers & Internet
Copy and Paste
Maybe your computer have some virus, that would interrupt some movements. If it is not the virus, try to replaced your keyboard and also the mouse.
Jun 17, 2008 | EliteGroup P4M800PRO-M Motherboard
D-Link DI 514 Wireless Router (DI-514) Logo
48 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
