Question about GPS
How do lowrance bluewater 1240 work? I bought a used Cajun Spirit Fish & Ski boat with one built in & have no idea how it works.Any help would be appreciated. Thanks-Bassman in RI
hydetech
  • 113 Answers
SOURCE: False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
Posted on Feb 26, 2008
  • 13433 Answers
SOURCE: lowrance LMS 337
I wonder if the module has failed again, have you tried reseting the device?
I'm looking into this but I suspect that repairs are required again.
Posted on Jul 09, 2008
CMV9
  • 594 Answers
SOURCE: When turning on the Lowrance
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
http://www.lowrance.com/en/Support/Troubleshooting-Guide/Depth-Reading/
please rate and comment on your experiance with fixya.
Posted on Aug 15, 2008
Benimur
  • 6966 Answers
SOURCE: i need a manual!!
Pls try here. Incidentally, you might fin this likewise informative.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 02, 2008
dirinda89
  • 214 Answers
SOURCE: brought a boat with lowrance x24 no manual with it
Here's a link where you can download the manual..
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good luck & have fun. If this helps you plz rate this 'fixya' for me. Thank you kindly.
Posted on Feb 11, 2009
1995 Cajun bass boat. Where can I get a wiring diagram?
cajun manual and parts manufactures
www.bbcboards.net > BBC Boards > Bass Boat Forums > Cajun Boats
Jul 18, 2011 - 13 posts - ‎11 authors
... for cajun boats and also a complete manual in pdf format and wiring schematics. ...bassmannbama is offline ... a wiring diagram too because switches arent working andmy wiring ... My email is : steve1995z@hotmail.com.
Cajun Boats Owner's Manual 1992+ available on pdf
Apr 19, 2012 - 4 posts - ‎4 authors
I scanned in my owner's manual and have it available if anyone is ... Mine is a '95 1950 Fish n Ski, but I believe it would cover bass boats as well. ... Looks like I'll need to learn about electrical and general boat repair.
Nov 19, 2015 | Boating
I have a 1996 17' cajun fish and ski boat and need a owners manual for it
I worked for a dealer for 20 years and never saw a manual for any boats.
May 26, 2010 | Boating
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
Lowrance lms 330
have a lowrance lms-330c the depth no. keep changing from hi no. to low no. can not stop it,,, will not show true depth,,, can you help?,,,where can i send it to get it fix?
May 29, 2009 | Lowrance LMS-330C GPS Receiver
I need a manual!!
you can find the manual here,
www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS339cDF_iGPS_0152-011_011206.pdf
Hope my info solves your problem,
Thanx for using fixya.....
Oct 02, 2008 | Lowrance LMS-332C GPS Receiver
Globalmap 2000 sonar not responding
Not enough info to diagnose your problem. It sounds like a networking problem. I couldn't find a manual for the sam-st module so I'm not sure how you have it hooked up. Typically with these devices only one would be hooked up to the SONAR module, and it would then share the data with the other display via an ethernet or NMEA2000 network. The erratic behavior of your bluewater could be due to some sort conflict with the current coming from the GlobalMap2000. Do you get the same problem when the 2000 is turned off? Have you tried running the GlobalMap2000 with the bluewater turned off?
Aug 04, 2008 | Boating
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
GPS Logo
334 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
