Question about JVC KD-G120 CD Player
Every time i turn my car off my radio memory erases.
My memory wire on my jvc kd-g120 is not working. what am i doing wrong
    President:
  • 2,992 Answers
Have you checked that the wire you are connecting to is constant 12 volts and not switched, and that any inline fuse is still good? Unless there is something wrong with the radio, the memory should work if you have the constant supply connected.
This site may be helpful with wire colors if your model car is listed.
Posted on Apr 19, 2009
Is a remote wire and memory wire the same
no, they are not the same. the memory wire is to maintain the memory of preset stations and the clock. the remote wire is to turn an amp or power antenna on. on some radios there are two remote wires. one for power antenna and one for amplifier. power antenna is usually blue, and amplifier is usually blue/white.
Dec 20, 2010 | JVC KD-G120 CD Player
Which color is the memory wire im tired of resetting time and audio configurations plz help
basically you have a power wire which should be wired to a switched connection and a memory wire which should be wired to a unswiched connection. look on your fuse box under the dash and connect the power wire first to a switched fuse (one that shuts off the radio when you turn off key) then look for a fuse (with same power wire )that when you turn off the key the radio stays on, this is the fuse that you connect the memory to,or you can connect the memory wire directly to the battery but you must use an inline fuse or you burn up your radio,car etc.
Jul 05, 2010 | JVC KD-G120 CD Player
How do you set the clock on the kd-g120r jvc car stereo
Turn the tuner on then push and hold the SEL button which is at bottom left of radio and then turn knob until CLOCK is displayed.
Apr 04, 2010 | JVC KD-G120 CD Player
Set radio to display time or station
Try this
http://www.retrevo.com/support/JVC-KD-G120J-Car-Receivers-manual/id/989dj895/t/2/
Mar 27, 2010 | JVC KD-G120 CD Player
I just hooked up an aftermarket cd player in my truck, I've double and triple checked the wiring and everything is correct yet when I shut my key off the radio doesn't turn off. What can I do?
Hello ron_bgsu,
Either the "accessory" wire is always on or the KD-G120 itself is faulty.
Use a voltmeter to check the wire you have connected to the RED wire coming from the CD player wiring harness. There should be voltage only with the key on or in the accessory position. If there's voltage on it with the key off, it's either defective or the incorrect wire. If the wire tests OK, the problem is in the receiver.
Hope this helps.
Jun 12, 2009 | JVC KD-G120 CD Player
How do i change the time on my jvc kd-g120
Press and hold the display button.
Jun 05, 2009 | JVC KD-G120 CD Player
Set the time on my jvc car radio
This did not work to set thetime on my raido
Mar 10, 2009 | JVC KD-G120 CD Player
Clock settings
this was very helpful with my problem
Jan 02, 2008 | JVC KD-G120 CD Player
I c an't set the time in my jvc kd-g120 audio cd player
Push the Sel button and hold for 3 seconds (usually displays Demo or Demo Off). Push the Station up and down button til it reads Clock H or Clock M. Turn the volume button to adjust time. Push the Sel button to quit.
Apr 30, 2007 | JVC KD-G120 CD Player
JVC KD-G120 CD Player Logo
710 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
