Question about Samsung SCX 4200 All-In-One Laser Printer
Noise during scanning
Recently my SCX-4200 started to produce a strange noice during scanning. It sounds like a strong vibration of plastic or like friction of two dry surfaces. I can imagine that it is OK, but in the past, I never experienced this symptoms. Any suggestions? :)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 171 Answers
You can very much open the scanning glass and check the nelt tension as well as two white clips which support the cis scanning unit with the glass (whether one of them might have come off)
Should resolve the problem in case the motor etc are ok
Happy scanning
Omnipresent
Posted on Oct 26, 2007
    Genius:
  • 2,985 Answers
Not really these are sealed units - nothing to repair. If it works grit your teeth and bear it. If you open it up and try to lubricate the offending parts the chances are you will kill it dead.
Posted on Sep 19, 2007
SOURCE:
I have a printer samsung scx-4200. when i click start button in order to make a copy it remains unchanged no voice at all and no errors as well, when i connect to the PC it is being detected by PC but the...
Appears to be a driver problem. Toward the end of the page of this supplied link are purportedly a couple of solutions. They may require translations. Either Google translate or Q Translate freeware may assist.
Updating to Mavericks Samsung Scx 4200 can no longer print and scan
Dec 09, 2017 | Samsung SCX 4200 All-In-One Laser Printer
I lost the cd for the software How can I get the scanning software? i am using Samusng SCX 4200
check this site and download only for scanning driver, http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=SCX-4200
Apr 06, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Scan error. making big noise each time after turn the all in one laser printer on.
Lift the scanner lid and look on the left side, sounds like the scanner lock is locked, easy to bump on this machine. It's under the lid where you lay a document when you make a copy.
Nov 20, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung scx-4200 does not give me the option to scan to pdf file
I used a program called SmarThru 4 with the same printer-scanner. Works. Give it a try :).
Jun 29, 2009 | Samsung SCX 4200 All-In-One Laser Printer
How to operate the scanner on samsung scx - 4200 model printer. how to scan using this printer.
a scan button will be there on the printer check it out press it to scan the desired paper
or else u can scan from the solution centre ..........goto start -programs--samsung printer--in that choose scanner
Nov 22, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Strange clicking noises
can you send me the audio of it for me to determine whats wrong.. thanks
Jan 13, 2008 | Nokia 445 X (White) 21 in.CRT Conventional...
Sharing with Samba/Cups
To my best knowledge, you cannot. The drivers and scanning software on your unit are not designed to support network protocols. Your unit does not come with an Ethernet adapter and it is not available as an option. When Samsung fits an equipment with a network card (such as the SCX-4521FN) the drivers and software are enabled for network use. By the way, your toner will only last for 3,000 pages. Are you sure it's a good idea to share such such a small unit over a 10 PC network?
Sep 25, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
141 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
