Question about Schwinn Mesa Gs Mountain Bike
Gears slip I have a new Schwinn ranger. The gears do not shift properly. When going up hill the gears do not engage and contentiously slip. Not sure how to adjust gears. Marty
I am a salesman from www.joyguy.com We mainly trade flashlight and other electronics. Feel free to contact us if you ar einterested in it, thanks.
Posted on Nov 20, 2010
    Scholar:
  • 34 Answers
Adjusting gears is a bit of an art. Let me see if I can give you the quick rundown. Lets focus on the rear set of gears.
1) shift the rear gears all the way down till they are in the smallest cog in the back.
2) line yourself behind the bike looking straight at the deraileur hanger and the small cog. (see this img - but do it to the smallest gear - http://www.mountain-bike-scotland.com/images/bikebay-gears8.gif)
3) The top pulley (jockey wheel) on the deraileur should line up with the smallest cog. If it doesn't, determine if it is to the left or right.
4) If the jockey wheel is to the left, that means that a) the cable is too tight or b) the deraileur stop is limiting it. First try to turn the cable barrel clockwise (while looking from the back of the bike). As you do this, does the deraileur start to drop. If so, good - line the jockey wheel up with the smallest cog. You should be good to go.
5) If this did nothing, then try to back off one of the two screws on the deraileur (phillips head). This should allow the deraileur to back down. If neither of these did the trick, they my essay here likely wont help. Else, your gears should be set. Now, get on and test ride the bike (helmet + a safe riding place). Shift the gear up just 1 click. If it caught, then you are good. If it tries to get up, but doesnt, go back to the deraileur adjuster barrel and turn it 90 degrees counterclockwise. Repeat the above step and turn 90 degrees each time till it goes smoothly. If you turn it more than 2 full turns, there is likley some other issue. Hope that helps...
Posted on Apr 19, 2009
96 ford ranger mazda b 2300 with 2.3 liter engine 5 speed when driving down the road and shifting gears the rpms rise before it goes. Into gear
Sounds to me like the clutch is worn and slipping. If there is chatter when engaging the clutch, it may also be a worn throwout bearing.
May 10, 2015 | Ford Cars & Trucks
My gears are slipping. how can i adjust them? the problem seems to be more in the 5th, 6th and 7th gear. this is a schwinn ranger mountain bike 2.6. it actully just started giving me a problem.
Sounds like your cable has stretched a bit and now the tension is off. There is a barrel adjuster where the cable comes into the rear derailleur. Turning this barrel too the right will increase the slack and turning it too the left will take up some slack.
Shift your gears to the middle of the cassette, then try turning the barrel 1/4 turn to the left, shift and see if it shifts into gear, if not shift back and adjust the tension again. Keep repeating till the gears line up.
if this does not work then it's time to take into a bike shop.
Apr 23, 2011 | Cycling
How do I adjust the gears, which have been slipping?
If you mean that your gears are slipping by means of the chain improperly engaging or riding along the walls of the cassettes outer gears, you can adjust the rear derailleur by means of a few tools. You can control how far in and out the derailleur moves by adjusting the two limit screws with either a proper fitting allen wrench or a small phillips head screwdriver. This won't have any affect on the inside gears but if it slips on the outer-most gear, it may help. You can then adjust the cable pull by hand on the adjusting knarp if present on the derailleur. It is the little (sometimes plastic shrouded) adjusting mechanism which the cable housing seats itself in. It is found directly on the derailleur and commonly on the shifter being used with the derailleur. You can rotate the knarp clockwise to loosen the cable or counter-clockwise to tighten. If the knarp has been threaded all the way in or too far out, you can return it to its original position and tighten or loosen the shifter cable manually using either a 5mm allen wrench, a 9mm box end wrench, or a specialty tool. Depending on the positioning of the derailleur and its design, tightening or loosening the cable will affect the position at which it is placed for each related gear. With a little bit of time and examining, you can hopefully figure out the most effective setting which would hopefully allow the derailleur to engage each individual gear without hesitation. To tell wether you adjusted it properly, follow these guidelines. 1, Make sure each gear being engaged is reflected on the position of the shifter. 2, When shifting gears by hand, the chain should not drop below the selected gear nor should it hesitate to move into the selected gear from its previous gear. 3, Check the limit screws position on the derailleur and make sure it is adjusted so your low and high gears are engaged without the chain slipping past the low or high gear, and slipping of the cassette. 4, When tuning the rear derailleur, make sure you account for the change in the chains travel path due to front chainwheel shifts.
- If the derailleur is not an issue, and you attempted to adjust it with similar results afterwards, look over the drivetrain of the bike closely while it is in motion and try to see the exact component that seems to be the source of the problem. I will be happy to dig deeper into this problem if you wish to ask another question regarding this issue. Good luck.
Mar 03, 2011 | Dahon Speed D7
1995 jeep wrangler, when shifting gears,having trouble going into gears.grinding bad.what could it be...
If the transmission oil is full and the clutch master cylinder is full, feels normal and does not slip going up steep grades, likely the gears in the transmission are worn (usually synchros). All items above contribute to proper shift engagement.
Apr 23, 2010 | 1995 Jeep Wrangler
When peddling bike seems to try to shift gears
There may be some chain links that do not move freely. turn the pedal slowly backwards and check for siezed links, as it goes through the deraileur.
A worn chain can do this as well, unfortunately you usually have to change the chain and sprocket cluster as a pair. If you just put a new chain on a similar problem can occur.
Apr 22, 2010 | Schwinn Mesa Gs Mountain Bike
None of the gears will engage
it sounds like something broke inside the transmission
Jun 16, 2009 | Ford Ranger Cars & Trucks
Transmission won't engage gears for more than a second
you can try shifting it manualy,which will eliminate the shift modulator,if it works you are in business..although it sounds more like not enough fluid in it,check the level warm,if you are more than 1 quart low it will act like that.
May 07, 2009 | 1987 Ford Ranger
Schwinn Mesa Gs Mountain Bike Logo
941 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
