Looping stictches on underside of fabric
When we sew the top stitches are perfect but the underneath ones are loopy and matted. I think the machine is threaded correctly and the spool is full etc. Any ideas?
  • 469 Answers
Your bobbin tension is likely too loose, this is one of the adjustments on the front of your machine.
increase it alittle`at a time until you achieve the desired results.
hope this is`of some help.
Ed
Posted on Apr 19, 2009
Tension on sewing machine
Check your stitch sample. The looping under the fabric is most likely the top thread. If so, this is call bird nesting or thread nesting. Most common cause is the top thread is not completely seated in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the top thread.
Set the top tension at the midway point (this can be tweaked later).
Test your stitch. Increase or decrease the top tension until the top & bobbin threads meet in the middle of your fabric.
What causes Bird Nests Superior Threads
Sep 06, 2017 | Sewing Machines
Needle stitch fine. Bobbin stitch loops.
First, try a brand new needle.
Second, consider using a better quality thread. By all means, AVOID old or bargain bin threads. Coats & Clark used to be a standard, but thread quality has improved over the past few years, so you may want to check out other brands like Aurafil, Superior, Isacord, etc. Also, cotton wrapped polyester thread releases thread lint that contributes to build-up of gunk in the machine. Some sewists have noted that they experience more sewing issues when using C&C threads. However, some machines will do better with certain thread brands than others, so some experimentation may be beneficial.
Third, check the stitch on your sample again. Generally, when thread loops appear on the underside of the fabric, it is the upper thread that is the problem. If loopy threads appear on the top of the fabric, it is the bobbin thread that is the issue. You can even use a different color in the top to help distinguish which thread is the problem.
Fourth, when threading the upper thread, Always Raise the Presser Foot during the threading process so the tension disk is released and the thread can seat properly. "Bird nesting" occurs when the thread is not seated in the tension disk.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Fifth, when the upper thread appears on the underside of the fabric, the upper thread tension is too loose. If the bobbin thread appears on the top of the fabric, the tension thread is too tight (or the bobbin thread is loose). Start out with the upper tension set at the midway point and tweak it from that point. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Also, remember that tension is not static--a tension setting for chiffon will most likely not work on cotton or denim. Get comfortable adjusting the tension to suit the project you are sewing.
May 24, 2016 | Sewing Machines
Janome 5900 sewing backwards!
Most likely, the bobbin thread is not in the bobbin tension. Rethread the bobbin and try again.
Loops on top of the fabric almost always mean too little tension on the bobbin thread; loops on the underside almost always mean too little tension on the top thread. Just backwards of most people's first guess. See http://www.picturetrail.com/sfx/album/view/22521551
Jan 18, 2014 | Janome Sewing Machines
Singer 2517c. When sewing, the bottom stitch is using to much thread, excessive amounts & the stitch isn't tight. I've tried all settings & have used a new bobbin. I'm at a loss......
Your description isn't very clear. When you say the "bottom stitch is using too much thread" Do you mean you see lots of loopy threads on top of the seam? Or do you mean you see loops on the bottom under the fabric? If your loops on the bottom, that means the top tension is too loose, you've not remembered to put the presser foot down, you have not threaded the top thread properly... Start by rethreading carefully with the presser foot UP. Then do a test stitch, remembering to put the presser foot down. If you still get loops underneath... tighten the tension.
If your loops are on the top of the fabric. loosen the top tension... then do a test seam... and if you still have loops loosen again and repeat. If you start to see loops on the bottom... tighten the tension a bit.
Good luck
Dec 30, 2012 | Sewing Machines
The top stitch is perfect but underneath the material there are many loops. I am assuming this is from the bobbin. How do I correct this?
no, more likely your top tension is too loose causing the loops on the underside of your fabric, loops on top would be bobbin too loose. raise presser foot and rethread top thdead pulling thread into tension fully. set top tension dial to 5 and test sew. if still looping underneath try tightening top tension by turning dial up to 6. but usually top tension should only need minor adjustment tweeks. you can test top tension by lowering pressure foot to engage tension and holding thread just above needle thread guide, pulling thread downwards . there should be resistence on it to your pull. if you cant feel any then tension device may be faulty, and require service.
Jun 25, 2011 | Sewing Machines
The bobbin thread is loopy on the under side of the fabric. I tried adjusting the tension setting but it didn't help at all.
Loops stitches on the underside is typically from the TOP tension being too loose, however it can also be the bobbin tension is too tight, or a problem with the needle. I would check them in that order.
Hold the bobbin thread and let the bobbin dangle. A slight shake of your hand should allow the bobbin to move downward (lets more thread out) but not so much that it just drops to the floor. When you put it in again and try sewing look at the top stitches. Do they look overly tight? THen the bobbin tension is too tight. The stitching should look the same top and bottom with no loops.
If both tensions seem to be alright check to see if the needle is: 1. the right size and type of the fabric 2. not bent
That should fix your problem :)
Jan 22, 2011 | Husqvarna Rose
Stitches are looping on the underneath and missing some stitches
Refer to the manual for cleaning.
Replace the needle with the size recommended for the type of fabric being sewn. The flat side of the needle is usually facing the back of the machine - check manual to be sure.
Always thread any sewing machine with the presser foot up. This opens the tension control so the thread can properly enter this device.
When a sewing machine is threaded with the foot down, the tension control closes and the thread cannot enter as it should
You then get loose stitches because the top thread and bobbin thread cannot make a proper stitch and the tension of the bobbin thread is pulling the top thread to the underside of the fabric.
Mar 07, 2010 | Janome Sewing Machines
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Singer Sewing Machines
The top thread is really loopy on the underside of the fabric, sometimes it misses a stitch, sometimes, the upper thread breaks, and it often gets so tangled underneath that the machine won't feed.
Your tension is way too loose on top or too tight on the bobbin. Try adjusting the top tension one number at a time until you get it right. (Only adjust the bobbin tension as a last resort). Also you could have different thickness of thread in the bobbin than on the top or are sewing a very heavy fabric. Try adjusting the tension with same thread in both bobbin and top and use a normal weight fabric until you find the right tension to get you back to a normal stitch before going to a heavier fabric or thread.
Nov 19, 2009 | Craft Master 4300 Mechanical Sewing...
jasbo
jasbo
