Question about Yamaha RX-V2600 Receiver
Yamaha RX-V2500 completely shut down
I live in a remote area, and there are not many services that will assist. I have a Yamaha Rx-V2500, which is my surround sound system attached to HDTV/DRV-Cablebox/DVD Player/CD player/CDR, etc.
If you are familiar with the product, you know it has Main System, plus 2 additional zones. Zone 2 and Zone 3 for additional areas. I have Zone 2 hooked up to my backyard speakers, and also have a seperate volume control knob that's wired to the wall.
I have found that if you inadvertently turn the sound on Zone 2 above
(minus)-15DB, from the remote or system, it will overload the speakers and shut them down. This does not happen on "main system" only Zone 2.
Yesterday, the remote and receiver were on Zone 2. (the outdoor speakers were on), I did not realize that I had not changed the remote back to Main System before trying to increase the volume on the television. When I attempted to increase the volume, since it was on Zone 2, the speakers outside overloaded and automatically shut off. (which was not unusual).
What happened next is. When I realized I had the remote on zone 2, I immediately changed it to "Main System" and then proceeded to try to turn up the volume on the TV (remote was on cable setting) At that point, there was a "click" and the entire system shut down.
I thought maybe just temporary surge, so I unplugged the system, waiting a few minutes, and tried to turn it on again. NOTHING. I hear a "click" but I see no power nor do any lights come on the receiver at all. Nothing on the main screen or anything.
So, I unplugged it and left it overnight. Again, tried this morning, and NOTHING. I just hear a "click" when I first turn on system power, but nothing comes on at all.
There is power going to all of my other components, so I know power is being generated. But, since the main receiver is not working, neither is anything else.
Sadly the company where I purchased who had a great repair division has gone out of business. There is no one for me to call, and most of the bigger companies won't come out to my area. I can't disconnect and try to bring somewhere, because all of the wiring is so very complex, I would have no idea on how to re-wire it.
Any direction or help is greatly appreciated. Yamaha DOES NOT even have a phone number or list of repair locations in their instruction manual.
Thanks to anyone who has any ideas.....
M. Pearce
  • merlinp512 Apr 20, 2009
    Hello Cable Guy
    Thank you for your response. Was the phone # you provided and International number? I did not recognize it as one from the US.
    Can you confirm? Thank you.
    Hi Cable Guy
    Thank you so much for the info. Can you tell me is that an International Phone #?
    I did not recognize it as originating out of US.
    Can you confirm? Thanks so much
    President:
  • Yamaha Master
  • 1,114 Answers
Sounds like the volume control on zone 2 is your culpret. You should set up zone 2 to have a "fixed" output instead of "variable" it's in zone 2/3 setup. whats happening is you are overloading the volume control from the zone volume on the receiver and getting feedback to the receiver and shorting it out. What you do is put zone 2 to fixed output. set the vol control to 3/4 then adjust the vol to relatively loud and exit out of settings. this will be your max volume setting. Now, on to your problem.Unplug the receiver. There is an internal fuse that could have blown, not to likely but it's possible. You have to take the top off the receiver with a #1 phillips or a T10 torx they vary. It's about 7 screws, pop off the top and look from front to back, you will see 1 or 2 fuses near the AC plug port. Sometimes they are gray or white and you cannot visibly tell if it's bad. If you have a multimeter, set it tone resistance. Then put your leads on either side of the fuse, if you hear tone the fuse is ok. If not check your leads by touching them together and you will hear tone then test again. If you don't have tone, your fuse is bad. Radio Shack should stock the fuse you need. If you don't already know this, there are 2 Power switches for your unit. Front of receiver bottom left corner "Master Power" and normal Power switch "Main Power" check them both. If your fuses are good and power is good, you have bad transistors internally and it needs to go to service. check www.yamahausa.com support and service, and you can find the closest authorized service center to send it to. If you mail it out directly to the service center rather than taking it to a dealer, you will save some money and get it back faster. Lastly, pull your zone 2 volume control and look for black marks on it or white chalky substance. "oxidation". If you don't mind spending a little money on the system, hardwire the speakers thru and replace the volume control with an IR receiver. If you could control the zone from the zone by pointing the remote at the volume control you had an IR vol control. You really didn't need the vol part. Xantech or Proficient make good IR receivers that aren't too expensive and will keep this from happening again. If you need any more help, I am a Yamaha Dealer, let me know where your located and I can send you to a good service center. Just post a comment and I'll get you the info you need. Hope this helps
Posted on Jun 06, 2009
  • 151 Answers
HI,Yamaha have now changed to "YAMAHA MUSIC",and the phone number is 01608366700,ask to speak to someone in tech.
Hope this helps.
CABLE GUY.
Posted on Apr 20, 2009
Hello
i have no problem with the sound as i did no adjust anything, however when i turn my yamah rx-v2500 it turns on and then off right away. It was working fine this morning, so I am not sure as to what the problem may be.. I am going to check the fuses but is it just the one fuse or is it both. I have one fuse that is white that is about 1 - 1/2 inches and the ohter one looks like its silver and is about 3/4 to 1 inch. please advise
thanky you
Posted on Aug 09, 2009
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
All digital inputs dead
Main control board fault. Contact the authorized service center. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 30, 2015 | Yamaha RX-V2500 Receiver
Where do I plug rca cables from the cable box into an RX-V2500 Yamaha receiver?
Depending on what type of connections your cable box has available you can do the following:
1) If yo only have the standard VIDEO & L R AUDIO connections you can use the DTV connection on the back of the V2500. If your cable box also has an S-VHS connection this would be the same connection to use.
2) If you have COMPONENT VIDEO connections on your cable box then you would still use the DTV connection. Looking at the back of your V2500 the regular DTV RCA connections are just to the left of center. Farther over to the left are the COMPONENT VIDEO connections. They are labeled Y, Pb, and Pr. These allow for the higher needs of HD TV transmissions. If your cable box has these connections then making use of them would allow for the best quality for your picture.
The following website has your manual available for download in case you need it:
http://www.devicemanuals.com/guide/Audio%20and%20Video/Yamaha/Yamaha-RX-V2500-Owner%27s-Manual-TVRBek9UVT.html
Please let us know if you need any further assistance with your issue.
Mar 12, 2010 | Yamaha RX-V2500 Receiver
Can you tell me please: where do you insert cables from a cable box to a Yamaha RX-V2500 receiver I appreciate any help you can give. OK. The cables that were attached to my cable box were removed when the...
the coaxial cable from outside is connected to in (box), coaxial cable from out to digital in (RX) digital out to TV... (try scrolling through source to cable/ or component if this is HD) (all other devices can be connect to RX also like dvd using Red Yellow White cable or S-video w/red & white)
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
Yamaha RX-V390
Try reseting the Yamaha-Shut the power off, and while holding down presets 1,2 and 3 press power on.
Nov 24, 2008 | Motorola Mobility DRC800 Universal Remote...
Onkyo HT-R520 Immediatly goes to standby mode when turned on
This Yamaha model has a "Thermal Protection Integrated Circuit", You can check the online manual at www.yamaha-uk/pdf/owner_manuals/rx-v2500.pdf
May 17, 2008 | Yamaha RX-V2500 Receiver
Yamaha RX-V800 - No audio on left and right channels
I too am experiencing this problem.... and my receiver is only 5 months old. Its a RX-V661
Oct 30, 2007 | Yamaha RX-V2500 Receiver
Yamaha RX-V2600 Receiver Logo
1,808 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
