Question about Sony PS-LX250H Turntable
Sony PS-LX300USB Turntable, one channel not working
I connected it to an older Sony amp and it worked fine for 2 weeks. then the right channel stopped working. This is the same thing that happened to my old turntable. Could it be the amp?
    Problem Solver:
Have you tried swopping over the output leads from the turntable to the amp (normally one red and one white phono plug) so they are in each others socket? If you do this and you still get no sound from the right channel it is almost certain to be a faulty amp,or speaker.
If you swop and get no sound from the LEFT channel it is could be either a faulty lead or cartridge.
Posted on Apr 19, 2009
I just replaced the stylus on my sony PS-LX300USB turntable, but now there is a constant static on even my new records
You have either knocked the connections to the cartridge causing a loose connection, or not seated the stylus right. Or you have static build up, which can be caused by poor earthing.
Mar 12, 2014 | Sony PS-LX300USB Turntable
No sound with Sony LX300usb turntable
I just received the Sony PS-LX300USB turntable but cannot play sound through the computer speakers. States to setup Playback USB Audio
CODEC which shows working and Recording it shows Microphone USB Audio CODEC which is working. How do I get sound???
Apr 07, 2012 | Sony PS-LX300USB Turntable
How do I connect a usb turntable to a Yamaha HTR 6230? Sony turntable PS-LX300USB preamp switch set to 'line'
hi,
Select the switch to line. Then connect the red and white RCA pins to the corresponding red and white sockets of MD/CD-R play input of Yamaha. Select the MD/CD-R by pressing the button on the remote. Then play the turntable.
OK
Oct 15, 2011 | Sony PS-LX300USB Turntable
I connected this turntable to a sony DAV-DX255 Home Theater System that does not have a phono connection, the turntable works, but the speakers are turned to the maximum and the sound is very low. What...
hi,
the output voltage from ur turntable is not enough for the aux in put of ur home theater. for connecting the same to ur home theater amplifier u need a phono amplifier. connect the turntables out put to it, and phono amps out to any one of the analog input of ur home theater amplifier.
ok
Dec 26, 2010 | Sony PS-LX300USB Turntable
Hooked up Sony' s PS-LX25OH record player to Harmon Kardon 235 AMP and no sound is coming from the amp. I did have the record player hooked up to a Sony Amo and it worked fine. Now all I hear is the sound...
First check that the amp is working by putting your finger on the imputs at the back. You should get a buzz on each channel. Or disconect the wires to the cartridge, with the turntable connected to the amp and the amp on, touch the loose wires (you won't get a shock). You should hear the buzz on both channels with two of the wires (left & right). If you don't the pre-amp for the cartridge in the amp has failed. Will be a single IC that's gone, found by following the wires back from the deck imputs inside the amp.
If it buzzers then the cartridge has gone.
Oct 31, 2010 | Sony PS-LX250H Turntable
PS-LX300USB Turntable: I have hooked up the sony turntable to laptop, but...
Have you though of using a pre-amp? You'll probably need to go turntable --> pre-amp --> soundcard input to get acceptable sound
May 11, 2010 | Sony PS-LX300USB Turntable
I need to determine appropriate stylus replacement for the Sony PS-LX300USB Turntable
any stylus should work i think radio shack sells them for pretty cheap and I know for sure that best buy sells them for cheap thats where I got mine. Best though from what I can remember is diamond tip but very coastly.
Apr 05, 2009 | Sony PS-LX300USB Turntable
Sony PS-LX250H Turntable Logo
490 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
