Question about Char-Broil Terrace 463243804 Grill
Trying to clean the burners assembly
I have a char-broil grill model 463243804. I am trying to follow their directions for cleaning the burner assembly: it says: "remove cotter pins from beneath each burner "foot" using a screwdriver or needle nose pliers." I can't find any such cotter pin, nor does it seem possible to life the burners up. Any thoughts?
  • Anonymous May 24, 2009
    Did you ever figure this out? I have the same problem
I found this pin. It's on the bottom of the burner on the back end. You have to slide your hand under the burner between it and the flang of the bottom of the grill. It's a messy and difficult thing to remove. Somehow I was able to wiggle and pull it out with my fingers, assisted by a screwdriver and needle-nose pliers. It was a huge pain the a$$ but I was able to get the three burners free and get a coat hanger in there to clean them.
Because of the bottom of the grill there was no clear visible access to these pins. You have to operate blind with just your fingers and the tools. Good Luck!
Posted on Aug 10, 2009
How to replace regulator/hose/valve assembly on char-broil gas grill?
Follow the hose back to where it connects to the gas rail , and go from there , to see what has to come off if anything .
Apr 21, 2013 | Grilling
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
Need a Burner Kit for a Char-broil 9000 DLX (Precision Burner)
You can order the burner directly from Char-Broil, if you have the correct Model Number. Go to
http://www.charbroil.com/Store/ReplacementParts.aspx
Hope this helped you. Please let me know.
May 08, 2011 | Char-Broil Grilling
I am trying to remove burners to clean. I have removed carry-over tube but can't get burners out. They seem to be in a bind. Are they attached anywhere or do I just pull out?
Look closely, where the spark ignitor touches the burner. You will see 2-sheet metal screws that attach the burner to the floor of the grill's casting. If you can remove those, the burner can be removed and slid of the venturi valves. These sheet metal screws will probably be covered with grease and a bit rusty. So, use caution when trying to remove them.
If it will be of any help and for future reference, I have included a link to your Owners Manual, that you can download and print.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
Hope this helps and Happy Grilling!!
Apr 12, 2011 | Char-Broil Advantage 463453306
How do youremove and replace a charbroil gas grill burner on model number 463268007
Here is a link to the Owners Manual for your model grill. It has the assembly instructions, so just reverse what they are and you'll be in business. As they say, "one picture is worth a thousand words."
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463268007%20manual%20-%20english_3d4c7147-c_.pdf
Apr 03, 2011 | Char-Broil Grilling
I'm trying to replace the paddle burners on this grill, but I don't know how to get the old ones off. Char-Broil said I have to disassemble the entire firebox to replace them. Is this correct, or is...
Hello, The model number that you gave is relatively simple to change the burners.
  1. Remove the 3 cooking grids
  2. Remove the 3 vaporizer tents
  3. Between each burner is a "pal nut" that just pushes on and will likely be destroyed when you remove it. They run a couple bucks each at Sears, part # 7000132
  4. This will release the carry over tube holding the burners down and the burners can be lifted out.
  5. Ensure that you clean out the carry over tube when you reassemble. This carries the flame from the first burner across to each of the rest of the burners when lighting them.
  6. Reassemble in the reverse order ensuring that you put the burner tubes over the burner valve tubes when reassembling.
You can find an exploded view with all the parts numbers at: http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001103_463453305_a.pdf
If this was helpful, please vote yes. Thank You!!
Oct 04, 2010 | Char-Broil Advantage 463453306
Burners two and three will not light unless direct flame is put to it. Burner 1 will light off the ignitor.
Hello, there is a carry over tube that looks like a burner hold down at the back of the grill. This is likely rusted closed and will need to be cleaned or replaced. The clips that hold the tube down are part # 7000132 and the tube part # is 7000279. They can be purchased directly from Char-Broil or Sears parts.
http://www.searspartsdirect.com
If you find this helpful please vote yes. Thank You!!
Mar 20, 2010 | Char-Broil Advantage 463453306
I'm trying to replace the burner on a Char Broil Master grill 7000
Should be able to get the burner assembly at any Lowes or Home depot store and not hard to change out. Old one lifts out and new sits right in. Hope this helps.
Mar 19, 2010 | Char-Broil 7000 Quick Set Gas Grill
Only one of four burners will light.
Hello, there is a carry over tube between the burners that looks like a burner hold down at the back of the grill. This is likely rusted closed and will need to be cleaned or replaced. The clips that hold the tube down are part # 7000132 and the tube part # is 7000280. They can be purchased directly from Char-Broil or Sears parts.
Apr 19, 2009 | Char-Broil Advantage 463453306
I have a char-broil 3 burner grill that is about 6 years old. It has 3 circular burners. The amount of gas now getting to the burners is equivalent to low even when the dials are on high. Do I have a...
most likely burner problem try removing burners (they generally just lift out or held by 1 or 2 screws) clean the sides of the burners with wire brush most likely then orifices on burners are clogged hope that works for you
Aug 23, 2008 | Char-Broil CharBroil 4637318 Grill
Char-Broil Terrace 463243804 Grill Logo
102 people viewed this question
Top Char-Broil Grilling Experts
paulcarew
Dean Gruber
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
