Question about Necchi Sewing Machines
I have a Necchi heavy duty sewing machine, I was hemming a denim skirt, the machine got bound up and now the threaded needle will not pick up the bobbin thread and bring it up. What could be the cause of this???
I have the same machine. Try replacing the needle, it could be slightly bent and not be in position to pick up the loop from underneath. A good de-fluff may help too.
Posted on Apr 19, 2009
Tension setting for sewing denim on brother LS 2125
Refer to 'Manuals Online', Brother sewing machine user manual. There is an excellent guide to tension settings for all fabric types. Also remember to check upper and lower thread has been wound through correctly and are using the same thread top and bottom. Ensure you have the correct needle size for denim ie 100/16 and the correct thread size ie 40-50 cotton or heavy duty polyester.
Nov 09, 2016 | Brother Sewing Machines
I'm trying to sew jeans hem and stitches are uneven on top and loops are showing underneath. Also the foot and needle will not sew over cross seams and thread keeps getting snarled up underneath. Tha
a lot of machines struggle with denim because it is such a heavy and dense textile. Many domestic machines won't stitch it at all due to this. Things you can try however:
  • Denim needle, this has a deeper groove at the back and is a heavy gauge needle, or use size 110 if you don't have denim needle.
  • Bash the side seams with a hammer in the area you will be stitching, to soften up the fibres.
  • Use a seam jumper, this is a piece of plastic to put in back of the presser foot as you approach a cross seam to help keep the presser foot pressure even across the fabric. Sometimes called a "thingy-a-jean" or similar.
  • Don't bother trying to use the heavy gauge yellow jean thread unless you put it through the bobbin and sew with the right side down. But even then, many machines can't handle having this heavy thread underneath and the regular 50 cotton on top, my Janome 1600 won't do it.
  • put your machine on slowest speed if you have a variable setting and turn the flywheel to assist it through the heavy side seams.
Personally, I never bother with the twice turned hem on denim if shortening, I just overlock the raw edge, turn up 1 cm and stitch around in a matching blue thread so it is seen as little as possible.
Feb 03, 2014 | Elna Sewing Machines
GC 500/550 not pulling bobbin thread. My wife has used the machine several times without issue, the last time she broke a needle sewing some denim, we found most of the needle but could not find it all,...
some sewing machines can not sew denim good,
here are some suggestions
since a needle was broken & replaced--if the needle has a flat side it goes to the back of the machine
make sure the needle is inserted correctly & pushed up inside of the needle holder & the needle screw tightened correctly
is the correct needle being used for the thread & fabric being sewed?
when sewing denim, a denim needle is needed, I usually purchase mine at walmart, I have 2 necchi sewing machines & the denim needles work just fine on my machines.
if none of the above suggestions help then the machine could be out of time, just because of a broken needle. only a repair shop has the correct tool to fix this problem
Sep 09, 2011 | Singer CG754 Mechanical Sewing Machine
I have a Necchi 3205 Royal series machine. I was sewing denim and it jambed and bent the needle. I replaced the needle and now it won't pull the bobbin thread up. I have tried several different needles...
Hi, I've got a necchi sewing machine too, not the same model as yours.
you said you were sewing denim & the machine jamed & bent the needle, it's sounds like the machine is out of time, sometime it doesn't take much to get them out of time & would have to be serviced by a repair shop with the tools needed to fix the timing.
Aug 29, 2011 | Necchi Sewing Machines
I have been sewing denim, and the top thread keeps breaking at the needle. What adjustments do I need to make. It also bunches from the bobbin.
Are you trying to use a heavy thread like buttonhole twist through the needle like the yellow thread on store bought jeans? Most domestic machines will not cope with this heavy thread and it will be too large for the eye of the needle too.
If you are using regular weight 50 polyester thread and its breaking then it could be because the top tension is too tight. Just loosen off 1/2 a number on top tension dial and see if this helps.
If possible, buy a pack of jeans needles size 100 too, these are blue coated with teflon I think, and makes it easier to slip through denim which is a very dense fabric.
Hemming denim jeans is probably one of the toughest jobs for a domestic sewing machine so if you are trying to do this, its a good idea to take it slowly and use a "humpjumper" which helps to maneouvre over the thick side seams.
However, even with all the above, many machines won't sew more than one layer of heavy dense weave denim.
Jul 20, 2011 | New Home HF-106
Will a NECCHI 535FA sew denim jean material okay?
Use a heavy needle and a product called jean-a-majig from Joann fabrics and you will be fine, just make sure you use the correct needle as this is key
Aug 21, 2010 | Necchi 3101 Mechanical Sewing Machine
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
Apr 08, 2010 | Necchi 3102 Mechanical Sewing Machine
Necchi Heavy Duty Sewing machine model 3205FA, bend needle while hemming denim skirt, replaced the needle, but now the needle is not picking up the bobbin thread, any suggestions for me to try???
Generally when the needle does not pick up the bobbin thread, it means the needle is either too far in or just plain the wrong length. YOu might want to try lowering the needle just a hair and see if that helps.
Apr 20, 2009 | Sewing Machines
Lower thread problem
are you still looking for an answer? if so I can help but I don't want to type all day if you already fixed it.
Sep 14, 2008 | Brother XL-6562 Mechanical Sewing Machine
I have a brother LS2125i it is easy to use, and I am a complete novice- but when I try to sew heavy denim- Like over the thickest part of the hem it makes a very load click nose- and becomes stuck--- is...
It may be the machine, although most machines would have trouble going over the seam. First, use a Denim needle, 90 or 100 and place a "shim" also called a "jean a majig" to keep the presser foot level. If the foot is shifted, the machine will not sew over the bulk. The machine is not real heavy duty, may have problems , anyway.
May 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
118 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
