SOURCE: i need driver of samsung
if you are having trouble
with your drivers
here is a general look at the
drivers and how to update them
if your computer came with
a motherboard disc the drivers could be on it
click start control panel
administrive tools ,computer management ,device manager look through all
of your devices if you see a yellow question mark?or exclamation mark
! or red x
right click to reinstall
drivers or
if you can see your usb but
its not working
ports(com&lpt)right
click update driver
hope this helps
SOURCE: my Samsung HX-MU010EA/G2 1TB portable
Have a look in disk management if on win 7 or vista just type in "disk Management" in your search bar after clicking start button and see if it shows up there. If not try plugging into another computer and see what happens. If still no good you say only 6 weeks it should be guaranteed. If your data is important to you never trust just 1 source of backup maybe start copying to DVD's also. Good luck with it from Scott
SOURCE: I have this product. "Samsung
You need a data recovery service. This guy does it remotely and just works off of donations. http://FreeDataRecovery.us
SOURCE: When I connect my Samsung
! or red x check
the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust
build up on them dust will cause static and a lot of unforeseen problems also
make sure the computers Ram and Cmos battery are securely seated
drivers or
its not working
ports(com&lpt)right
click update driver
sometimes the wires inside
the cable will be damaged due to bending or stretching or placing heavy
equipment upon the cable,
just replace the cable of
the hard disk, when you plugged the external disk drive you got that
windows could recognize the USB device change the cable everything should work
fine again,
if this fails to fix the
problem you might have to install a usb 2 or 3 card they are cheap and easy to
install you can buy these on Ebay very cheap if this solution does not work and
you might need one
hope this helps
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=280406610810&ssPageName=STRK:MEWNX:IT $1
+ $2.46 postage worlwide
You might get these on Ebay
im not sure which country you are in this might guide you to one
you could get this on Ebay
if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal
login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration
password ,bank card /credit card phone numbers home/mobile ,email adress
and a postal adress
be very specific when you
type in the search
always ask questions?
before you make a purchase and keep the email/s for security reasons if the item
arrives and its not as described
you will even see the
pictures of your item so you cant make a mistake and get them home delivered
hope this helps
you might need some third party software to change it from ntfs to fat 32
Partition Magic 8.0
http://www.filehoo.com/download/Partition-Magic-8,0.aspx
or
http://download.cnet.com/easeus-partition-master-home/3000-2248_4-10863346.html
hope this helps
