Question about WeatherWorks CH-1850SFW Riviera Stand (Pedestal) Fan
Where the fan assembly goes on the peditol base the plastic just below the fan controls is broken. Are there pieces you can buy.
Motor base cover for dlc 7 super pro
Try buying a new motor base on eBay. It's actually quite cheap. If you are daunted by the shipping cost of this monster, you can always ask the seller to sell you just the brown bottom cover. Under each foot is a screw which attaches the molded base it to the rest of the assembly. It's a lot cheaper to just have that part sent to you. This works as long as you are handy in making the switch of the base.
May 27, 2014 | Cuisinart DLC-7SFP Pro Food Processor
Trigger on my dc07 does not open cylinder flap,what can i do
Hi Stephen,
This is a pretty uncommon problem and it is not terribly easy to fix. I suspect Dyson became aware of it and changed the mechanism as I have only seen this issue with Dyson DC07. Basically there is a long plastic rod from the trigger to the bottom flap when you pull on it the latch is released and the flap opens. Your plastic rod has most likely broken. The unfortunate thing is you cannot buy that rod you might have to buy the complete radix assembly. It normally happens that the bottom end breaks off when someone holds the base in place and pulls the trigger.
If this is the case then you may be able to super carefully glue the pieces back together. Watch the video I linked below it shows how to get the radix apart. The tricky part for you is that you will then need to insert a coat hanger or some other slim long thing into the centre and manually push the release which is right at the base of the radix in the middle this will release the flap.
From there see if you can find the broken bit and repair the pieces. Super glue wont hold, you will need araldite or some other super strong compound.
Of course if this sounds like too much trouble just buy a new radix.
May 24, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you replace the antenna cable on a 2002 Chrysler Voyager
Yes you need to remove the liner and access it from there.
Oct 04, 2017 | 2002 Chrysler Voyager
The base where i lock de fan for the cpu it broke in one side the fan is hook only en 3 corners can i buy the plastic base atach to the motherboard?
you can collect from damaged mother board (intrel p4).Youb should go nearest computer technician collected from them.shibuda.jpeg
Hope this helps.
Jan 12, 2011 | EliteGroup P4S5A Motherboard
Problem with shaver
are you talking about springs under the center cutter bar between the foils? If so, you will need a new foil and cutter set. It is available at shaveroutlet.com with link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
Or maybe you refer to a spring that goes to one of the clips that hold the foil assembly to the pivoting swivel frame. If so, you will need the part linked below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Jan 14, 2010 | Braun 360° Complete 8985 Electric Shaver
Frigidaire dishwasher - upper spray arm trouble?
I do not have a problem w/the upper arm not spinning. Rather, the upper arm keeps falling off of my frigidair dishwasher. The owner's manual suggests the upper arm is a single unit. However, the upper arm component is comprised of 3 parts. The parts are an arm that distributes the water, the base that screws to the top of the dishwasher, and a small plastic type washer that rides in the base and literally holds the arm to the base. The plastic washer has two small clips that tend to wear or contrast with age; thus letting the arm fall off on a very frequent basis.
Potentially, the small plastic washer piece may have broken in the base assembly and is not allowing the arm to turn. As water flows into the arm from a hole in the base; suggesting the plastic washer may be jammed with a foreign item seems less likely. The base unit screws to the top of the dishwasher and can be removed by hand (the base is a little tight). There are no mechanical pieces to my third (upper) arm; movement of the arm is accomplished with water flow.
You may wish to remove the arm assembly and check for a broken washer or a foreign item in the assembly. As a side note, I found that I can unscrew the base and remove the assembly without removing the top dish tray. The fit is a little tight but the tedium of pulling and reinstalling the top tray can be eliminated by unscrewing the assembly w/the tray slid forward for assembly access.
Hope all you have is a foreign item that is locking the washer.
Nov 03, 2009 | Frigidaire Dishwashers
The drum will not spin anymore. The drum turns
the most common problem is a broken DOG ASSEMBLY.
Pull off the softener dispenser
pull off the cap
take out the bolt
pull off the top of the agitator
you should see a broken plastic piece laying there
real cheap to buy one
next thing to check is the top door safety switch, does it click when you lower the door? Is the switch actuator broken off of the door?
Anything else is EXPENSIVE to fix.
Oct 30, 2009 | Whirlpool LHW0050PQ Front Load Washer
Midea electric pedestal fan
Try the internet. - SCB
Aug 05, 2008 | Midea Dryers
Broken piece connecting timer and thermostat
These are the guys you need to speak to; http://www.esalton.com/control/contactus 1-800-233-9054 Hope this helps - please ask again if you get no luck from them :)
Apr 15, 2007 | George Foreman GGR62 Grill
WeatherWorks CH-1850SFW Riviera Stand (Pedestal) Fan Logo
Top WeatherWorks Dryers Experts
Are you a WeatherWorks Dryer Expert? Answer questions, earn points and help others
