Question about Sekonic L-358 Flash Master Light Meter
Meter is consistently a half to a full stop off
My Sekonic flash master L-358 consistently reads a half to a full stop off. What can I do to adjust it?
    Brigadier General:
  • 3,006 Answers
I've known this problem to occur if the wrong kind of CR123/CR123A lithium battery is used. They come as rechargeable and dry cell (i.e. non-rechargeable) versions. For sensitive devices like yours the difference is important as the internal resistance of the rechargeables is lower which affects the voltage characteristics.This meter is designed only for the dry cell version: see page 34 of the user manual, although the instructions don't make this fact clear enough IMHO. The reason for using the dry cell version is that the output voltage remains constant until the battery is nearly exhausted, but the rechargeable version starts at a slightly higher than nominally rated voltage and drifts down as the battery discharges. This means that you only get a truly accurate reading with a dry cell battery. There is no user adjustment to recalibrate the meter but you can use a different ISO rating to compensate or use the exposure compensation settings.
Posted on Jul 04, 2009
Sekonic Flashmate water damage
It may be permanently damaged. However you can try this - pack it in a bag of uncooked white rice and leave it there for a few days. Uncooked rice is hygroscopic - it absorbs moisture from the immediate surroundings.
Apr 01, 2014 | Sekonic L-308s Flashmate Light Meter...
148 GTL - 4 Pin reading incorrect on meter.
The SWR circuit in the radio basically consists of a group of diodes and network---less than ten parts
I would get a schematic (old ones should do) and check the diodes and the path from them up to the meter.
Mar 11, 2012 | Radio Communications
I use the settings recommended by my L358. However, when I set my camera to those settings in manual mode, my photos are dark. Why is this happening?
The fault is either with your camera/lens or with the meter itself. Try the meter with another camera, if the exposure error is still present then check that the custom compensation feature on your meter has not been set by mistake (page 26 of the user manual). If this doesn't cure the fault then try fitting a new CR123A battery. If the fault still remains then you can either compensate for the error by always using a longer shutter speed/wider aperture than recommended or you will need to send the meter for servicing.
Good luck, and please take a moment to rate my answer.
Aug 29, 2010 | Sekonic L-358 Flash Master Light Meter
L-358 light meter doesn't change modes
Most probably the switch under the Mode button went faulty. Try to operate the button many times, sometimes it helps, if the culprit is corrosion or small debris inside the switch. If not, have the meter repaired at Seconic.
Oct 12, 2009 | Sekonic L-358 Flash Master Light Meter
Sekonic L-358 light meter will not trigger my photogenic lights anymore? Thanks, Liz
Hi Liz
have you checked your sync cable?
tried meter on another system (for comparison)?
Depends where you are.. Mamiya in the USA can solve the problem.
Jun 08, 2009 | Sekonic L-358 Flash Master Light Meter
I have a hanimex sekonic light meter but have the instuction manuel
http://www.sekonic.co.jp/English/product/meter/download.shtml
Mar 06, 2009 | Cameras
Error code 9 - 358
Hi,that means ,cleaning auger is stopped.Probably toner waste container is full.Try to remove and replace waste toner container(or vacuum toner from container).
BR
Feb 20, 2008 | Xerox DocuColor 12 Printer
Dark Images Indoor
This may sound dumb but is the flash going off? The second thought is how far are your subjects from the on camera flash. As you're probably aware, the flash is challenged as the distance doubles; half the light at twice the distance from any point. An equivalent example; f/4.0 @ 1/125th of a second worth of light at ten feet but you'd have only half the light available at twenty feet. So you'd have to change either your f/stop or shutter speed by one stop to either f/2.8 or 1/60th of a second. This is why the distance is so important. I don't see a hot spot on your subject matter so I'm guessing the flash isn't going off. Could be wrong as you're there so you'd know.
Sep 13, 2005 | Kodak DC4800 Digital Camera
Sekonic L-358 Flash Master Light Meter Logo
382 people viewed this question
Top Sekonic Cameras Experts
Are you a Sekonic Camera Expert? Answer questions, earn points and help others
