Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Free wheel i want to know how to put a troy built tiller into free wheel
  • 69 Answers
Shift your Wheel gear lever to "disengage". Use the disengage position only when the engine is not running.
Posted on May 06, 2009
Where is the model # on troy built tiller
If this is a genuine Troy ... (built in Troy, New York, by Garden Way) find the information stamped on the transmission housing left or right near the tire.
May 03, 2010 | Troy-Bilt Pony Garden Tiller
Disengage wheels from transmission
Pull out the bolts that bolt the wheels to the axle,then the wheels will freewheel.
Apr 26, 2010 | Troy-Bilt Pony Garden Tiller
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I can't move my Troy-Bilt tiller unless it's running.
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do I remove the wheels on a 1985 Troy Built Horse Rototiller?
Horse wheels are held on with a single roll pin. Pound out the roll pin and pray.....that the rims aren't rusted to the shaft. If the rims are rusted to the shaft, you have two choices. You can either put the new tires or tubes on the rim with the rim on the shaft...or you can work at getting the rims off the shaft. If you put tubes in, be sure the rim is free of sharp edges.....or you'll be sorry.
To get the rims off if they're rusted on, I've used a variety of techniques over the years. The most effective is to weld a nut on the spot where you removed the end caps. Use a nut that's the same thread as your bearing puller. Then use the bolt from your bearing puller to put pressure on the end of the shaft, pulling the rim off. A torch helps, but be careful or you'll be putting new seals in too.
Jun 09, 2009 | Troy-Bilt Pony Garden Tiller
My neighbor let us use his troy built tiller and it needs oil but he doesn't know what type of oil to put in the transmition. please help
The recommended lube for a Troy Bilt transmission is 140 Gear Lube. It's tough to find. If you use lighter oil, the trans seals will likely start to leak.
Jun 06, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Changing the drive belt
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
257 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
